Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Site Help and Suggestions
Old 03-01-2012, 10:31 AM   #1
mastic sealant help!!!
I've just had the mastic sealant put into my new kitchen and the tiler has used the wrong colour - what's the best way to remove without damaging my new tiles and work surface
jolewis21 is offline   Reply With Quote
Old 03-01-2012, 10:53 AM   #2
Are you sure you do not mean grout sealent?
Old 03-01-2012, 11:01 AM   #3
your're probably right - I don't decorate I'm afraid it's the stuff that goes between worksurface and tiles
Old 03-01-2012, 11:06 AM   #4
Stuck in the 70's
Blondesense's Avatar
If you're talking underneath the tiles don't sweat it. It will be covered by the grout.
Grout is used between the tiles. Caulk is used generally along the edges. If it is the grout you want to change, you can either dig it all out, or possibly stain it a different color with a grout stain.
The Following User Says Thank You to Blondesense For This Useful Post:
jolewis21 (03-01-2012)
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
Countertop sealant leaves granite with a dull finish? HeyItsJoel Tiling, ceramics, marble 6 05-31-2010 07:00 AM
new tile old mastic txdsf51 Tiling, ceramics, marble 1 08-31-2009 07:02 AM
help for removing mastic from aspestos tiles shellystar Flooring 1 06-16-2009 03:04 PM
