Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Site Help and Suggestions
Old 09-17-2006, 06:43 PM   #1
Goodman HVAC gmp100-3 Inside blower problems
The cooling cycle was being used and i notice that the inside blower was cycling on and off every 30 seconds. I turn the cooling thermostat to the off position. The blower kept cycling on and off, but the compressor did follow the action of the blower. The Thermostat has been replaced twice. I removed the thermostat wires and the blower kept cycling. I will test the hi limit switch and flame rowout switch.
ray_adrea is offline   Reply With Quote
Old 09-17-2006, 07:31 PM   #2
World famous jerk.
It sounds more like your ICM is hosed up.
mdshunk is offline   Reply With Quote
Old 06-28-2007, 01:29 PM   #3
having same problem, what did you do to repair?
don1354 is offline   Reply With Quote
Old 06-28-2007, 01:30 PM   #4
Old 06-28-2007, 01:31 PM   #5
gmp100
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Today we’re replacing a thermostat will not cut off, it just continuously runs. Inside the A/C closet, which is right around the corner, there’s a light switch kind of like this one without a plate on it and you’re going to turn that... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about locating and replacing your thermostat. The first step to locating your thermostat is to locate the large tubes coming out of your radiator. On this particular car... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a leaf blower. Okay so we've turned the on switch on or the kill switch to the on position, we... Read More »
History of HVAC Industry Brands winkydink HVAC 7 01-13-2010 12:30 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
Goodman furnace problems GMT045-3A wcoent HVAC 7 12-18-2006 11:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
