Can't Create Paragraphs? - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 07-11-2011, 12:33 PM   #1
Can't create paragraphs?
Everything I've typed gets crammed into a single paragraph, but I can see this doesn't happen to everyone's posts. Other folks can post in multiple paragraphs. Is there a setting somewhere I need to adjust? And if this sentence isn't all by itself, the way I typed it, then you can see what I mean.
BRIANisMEisWE is offline   Reply With Quote
Old 07-11-2011, 02:51 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Hitting the "enter" key once will move you down to a new line.
Hitting it twice will leave a space between the paragraphs.
Old 07-11-2011, 03:59 PM   #3
DIY staff
Rewards Points: 7,174
That's right!
That 'Enter' key.----Don't feel bad----I had to ask a friend when I started typing on a computer.--
Old 07-11-2011, 04:36 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
I just made a post and I had paragraphs in the post until I hit the submit reply button. When the post showed up on the board there were no paragraphs at all, it was all jamed together like BRIANisMEisWE said. I will now make another paragraph to see what happens.
OK, here is another paragraph, lets see if it jams together when it gets to the board.
OK OK, it worked that time, did some one do something?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-11-2011, 04:42 PM   #5
DIY staff
Jiju---Just a swarm of common computer gremlins----they are hatching out due to the warm weather.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (07-11-2011), Willie T (07-13-2011)
Old 07-11-2011, 05:10 PM   #6
the Musigician
DangerMouse's Avatar
*STOMP!*
got one.....
DM
Old 07-11-2011, 05:11 PM   #7
the Musigician
*STOMP-STOMP!*
got two more.... try it now.
DM
The Following 2 Users Say Thank You to DangerMouse For This Useful Post:
BigJim (07-11-2011), oh'mike (07-11-2011)
Old 07-11-2011, 06:32 PM   #8
Testing. Testing. Testing. There should be four lines separated by three blank lines. Oh, and I was using the Enter key. I've been doing this a long, long time. Now I should have five lines separated by four blank lines.
Old 07-11-2011, 06:33 PM   #9
Old 07-11-2011, 06:33 PM   #10
Test.
Test.
The monkey ate the banana.
Old 07-11-2011, 06:35 PM   #11
Solution: I use NoScript with FireFox, and it was blocking the Java script used by this page. I just enabled the scripts on this page via NoScript, and....
I have paragraphs.
Old 07-11-2011, 06:37 PM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Originally Posted by DangerMouse View Post
*STOMP-STOMP!*
DM
Jim
Old 07-11-2011, 06:45 PM   #13
kwikfishron's Avatar
Rewards Points: 1,010
Thank you for being concerned about paragraphs. I assume a comma here and there is important to you too.
I wish all new members (and some old) were as concerned as you.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
cocobolo (07-14-2011), oh'mike (07-13-2011)
Old 07-13-2011, 07:43 AM   #14
Old School
Willie T's Avatar
Yep, Gremlinss.
My keyboard hass ssudenly taken to typing out double esses about 80% of the time.
Or it might be lazy fingerss..
Willie T
Old 07-13-2011, 07:48 AM   #15
DIY staff
Coffee jitters,Willie.
Using faux stones to create a tree ring Mike Rynearson Landscaping & Lawn Care 1 06-04-2011 05:22 PM
How to create this texture yxw168 Painting 2 11-11-2010 04:58 PM
safe to create notch in studs pookieman Building & Construction 13 06-14-2010 04:30 PM
How to create a cove transition between ceiling and wall? D-Hoggs Drywall & Plaster 2 03-13-2010 09:16 AM
create positive slope when siding is at grade? pfisch Building & Construction 4 03-22-2009 09:18 PM
