Attach Dryer Vent Hose - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 08-06-2010, 02:58 PM   #1
attach dryer vent hose
Help!!!
I have tried to no avail to attach the vent hose using a clamp. I cannot get the clamp tight enough to hold the hose on. I have tried to tighten with my fingers and plyers. Is there another way to attach the vent hose besides using that clamp???
Peppermint is offline   Reply With Quote
Old 08-06-2010, 03:20 PM   #2
Electrician
Proby's Avatar
Screws would hold it tight, but I've read that they could catch the lint and cause a clog. I use a good quality 3" wide duct tape. Make sure to have the outside of both pieces clean and lint free so the tape can adhere properly.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 03:38 PM   #3
Civil Engineer
Rewards Points: 4,568
Many hose clamps have a nut that can be turned very tight (too tight in fact) using a nut tool. If you use duct tape to hold on the duct, be sure to use aluminum duct tape, as ordinary duct tape may catch fire, especially as it ages and gets brittle.
help with dryer. vent size problem? semidevil Appliances 9 09-06-2013 04:10 PM
Dryer vent with 4" PVC pipe rjniles Appliances 30 07-01-2010 09:21 AM
Dryer vent path Cossack HVAC 1 01-14-2009 09:57 PM
moisture in dryer vent and door monkeygirl Electrical 13 01-10-2009 10:11 AM
dryer vent insulation choppynuts Building & Construction 8 07-30-2008 09:02 PM
