Ad's Over Posts - Site Help and Suggestions - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Forum Support > Site Help and Suggestions
Old 02-08-2014, 08:42 AM   #1
Rewards Points: 280
Ad's over posts
Makes the site almost useless! JIm
jjrbus is offline   Reply With Quote
Old 02-08-2014, 10:33 AM   #2
Rewards Points: 738
I can't imagine anyone not wanting to read a book that a few words or portions of words are missing from the right side of each page.
Old 02-08-2014, 12:30 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
We have a new, highly experienced Admin, who is working hard with the tech guys to straighten out all the problems, as we speak. A lot has already been accomplished, and things should be solved soon, we appreciate you letting us know when things aren't going right.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-08-2014, 01:00 PM   #4
Rewards Points: 738
Thanks Jim
The Following User Says Thank You to SeniorSitizen For This Useful Post:
BigJim (02-08-2014)
Old 02-08-2014, 07:16 PM   #5
Davejss's Avatar
Rewards Points: 740
Seems to be happening less frequently.
Davejss is offline   Reply With Quote
Old 02-08-2014, 09:49 PM   #6
Rewards Points: 3,753
What window size and screen resolutions are you guys using?
I finally managed to duplicate the problem but only in threads with images in the thread. I had to reduce my window width to about half my normal resolution. No images and the threads wrapped normally. With an image the wrap stopped at the image width and the ads on the right came over the post. This happened with both IE and FF. In neither case the posts below the ones with images wrapped normally.
To the best of my knowledge this would be 100% normal. Images break pages; big images break them faster. The only solution that come to mind would be not to allow the scripts to place uploaded images inline and only show them as thumbs.
I took some screenshots but will not post them.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-10-2014, 01:33 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
If there is a carpet or vinyl question and I don't respond, it is because ads are covering part of the post. I will no longer guess at what the poster is asking. Maybe someone who can see the posts will respond.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-10-2014, 04:50 PM   #8
Rewards Points: 280
I use 2 screens one is 37" and the other is 22" measured diagonally. MOstly I am using Firefox. The 22" is 1280X720.
I visit many sites on an average day and this is the only site I have this problem with.
Good luck Jim
Old 02-10-2014, 07:47 PM   #9
Rewards Points: 56
Good luck Jim
I visit at least thirty forums a day, this is the only one with this problem.
Old 02-11-2014, 10:53 AM   #10
Administrator
Cricket's Avatar
Rewards Points: 562
Can you provide me with a link to a thread where you are experiencing issues so I can research this issue further please?
Cricket is offline   Reply With Quote
Gazebo Beams and Joists and Posts power_tree Building & Construction 0 09-07-2013 07:55 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
