Worn Out Drill Bits Or Chuck? - Tools - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 07:48 PM   #1
Rewards Points: 1,062
Question
worn out drill bits or chuck?
i have this keyless chuck drill
http://www.milwaukeetool.com/tools/d...k-cord/0302-20
it is awesome and powerful but, as of late, it loses grip on bits and they stay in lumber when i try to pull them out. i drill real slow and gently and all but still.
my question is whether the problem is with the chuck itself or maybe worn out bit shafts. or both?
thanks
Old 02-04-2012, 07:54 PM   #2
Missouri Bound's Avatar
It's the chuck.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
amakarevic (02-04-2012)
Old 02-04-2012, 08:01 PM   #3
so, replace the chuck?
Old 02-04-2012, 08:06 PM   #4
Rewards Points: 13,300
Jacobs makes a great racheting chuck, not cheap but would work as goo or better.
Old 02-04-2012, 09:23 PM   #5
Yep..replace the chuck. Has the drill been dropped on the chuck, is it rusty or difficult to turn? You could try removing it and soaking it in a solvent, but if it's worn it won't do anything except clean it.
Old 02-04-2012, 10:49 PM   #6
nope, none of that
Old 02-04-2012, 10:54 PM   #7
Nothing more you can do at this point except replace it. But you could write an email or call Milwaukee and tell them how pissed you are. I had a drill with the exact same issue.
Old 02-04-2012, 11:04 PM   #8
http://www.jacobschuck.com/product_details.asp?pid=25
amakarevic (02-05-2012)
Old 02-05-2012, 11:41 AM   #9
In a little over my head
Rewards Points: 706
Have you tried lubing the inside of the chuck? Try a shot of WD-40 or similar on the gears before you condemn it.
But, chucks do go bad.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Old 02-05-2012, 03:00 PM   #10
Question
have not yet but certainly could. WD-40 or machine oil?
Old 02-05-2012, 06:41 PM   #11
Rewards Points: 706
I'd start out with WD-40. That'd clean out any old sawdust and lube.
Old 02-05-2012, 06:42 PM   #12
thanks! (where is the thanks button?)
Old 02-05-2012, 07:06 PM   #13
Bottom right in your text box....
Old 02-05-2012, 07:10 PM   #14
don't see it.
Tags
drill , drill bit , drill chuck
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 06:40 PM
help My battery drill's chuck won't hold the bits robut Tools 2 06-27-2011 10:53 AM
Why can't I find straight concrete drill bits? DawsonMobley Tools 13 12-13-2010 01:31 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
