-   Tools (http://www.diychatroom.com/f29/)
-   -   worn out drill bits or chuck? (http://www.diychatroom.com/f29/worn-out-drill-bits-chuck-132568/)
amakarevic 02-04-2012 06:48 PM
i have this keyless chuck drill
http://www.milwaukeetool.com/tools/d...k-cord/0302-20
it is awesome and powerful but, as of late, it loses grip on bits and they stay in lumber when i try to pull them out. i drill real slow and gently and all but still.
my question is whether the problem is with the chuck itself or maybe worn out bit shafts. or both?
thanks
Missouri Bound 02-04-2012 06:54 PM
It's the chuck.
amakarevic 02-04-2012 07:01 PM
so, replace the chuck?
joecaption 02-04-2012 07:06 PM
Jacobs makes a great racheting chuck, not cheap but would work as goo or better.
Missouri Bound 02-04-2012 08:23 PM
Yep..replace the chuck. Has the drill been dropped on the chuck, is it rusty or difficult to turn? You could try removing it and soaking it in a solvent, but if it's worn it won't do anything except clean it.:whistling2:
amakarevic 02-04-2012 09:49 PM
nope, none of that
Missouri Bound 02-04-2012 09:54 PM
Nothing more you can do at this point except replace it. But you could write an email or call Milwaukee and tell them how pissed you are. I had a drill with the exact same issue.:cry::cry:
joecaption 02-04-2012 10:04 PM
http://www.jacobschuck.com/product_details.asp?pid=25
ratherbefishing 02-05-2012 10:41 AM
Have you tried lubing the inside of the chuck? Try a shot of WD-40 or similar on the gears before you condemn it.
But, chucks do go bad.
amakarevic 02-05-2012 02:00 PM
have not yet but certainly could. WD-40 or machine oil?
ratherbefishing 02-05-2012 05:41 PM
I'd start out with WD-40. That'd clean out any old sawdust and lube.
amakarevic 02-05-2012 05:42 PM
thanks! (where is the thanks button?)
Missouri Bound 02-05-2012 06:06 PM
Bottom right in your text box....
amakarevic 02-05-2012 06:10 PM
don't see it.
