Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-12-2010, 05:36 PM   #1
Wire Welder
I have a Hobart Handler 135. As many of you know, when you change to a new roll of .030 wire, about 5 foot of wire is wasted. Seem like there could be a way to attach this wire to the new roll. I have about 15 such scrap pieces that I have saved.
Any ideas??
Giles is offline   Reply With Quote
Old 12-12-2010, 05:51 PM   #2
nap
You talking to me?
nap's Avatar
Wire Welder
Not worth the trouble. You try to run some scabbed up connection through the liner and you will hate yourself. Just consider it a loss and dump it unless you have some other use for it.
Old 12-14-2010, 01:37 PM   #3
uva uvam videndo variafit
WirelessG's Avatar
Wire Welder
I agree with Nap. The most you could save is 1 cent and you would need specialized tooling to make it work.
WirelessG is offline   Reply With Quote
Old 12-14-2010, 02:46 PM   #4
fabrk8r
fabrk8r's Avatar
Wire Welder
Use it for tie-wire or put it in the scrap bin. As nap and wirelessG said, if you try to attach it to the new roll and run it through your whip you'll ruin a $15.00 liner to save a 1 cent piece of wire.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 12-14-2010, 07:11 PM   #5
Wire Welder
cant you just feed the new wire in and let it push out the old piece still making a welding connection ... until it runs out and the new wire starts ?
oldrivers is offline   Reply With Quote
Old 12-14-2010, 08:09 PM   #6
Wire Welder
I thought about that. I am sure the two ends would fuse together and that could create a problem. I just wonder what diameter the lining is. Probably larger then the small wire and they could wedge.
Old 12-15-2010, 12:10 AM   #7
WirelessG's Avatar
Wire Welder
Giles - I think that is exactly what would happen.
Old 12-19-2010, 04:58 PM   #8
Wire Welder
Any ideas??
Donate it to The Garrot Institue of America
Ron
Old 12-19-2010, 08:45 PM   #9
Concrete & Masonry
Wire Welder
Will it fit bigger spools of wire, like say a 10#? Going fro 2# to 10# will save you alot more money than a few feet of wire. I think mine may even have a 20#, but I can't remember because it's been so long since I needed wire.
jomama45 is offline   Reply With Quote
Old 12-21-2010, 09:53 PM   #10
Master General ReEngineer
Bondo's Avatar
Wire Welder
Ayuh,..... Get yerself a Spool-in Gun....
My Readi-welders Waste about 10" of wire at the end of a spool.....
Wire Gauges, Amps and Small Fixtures RedBear Electrical 1 11-06-2010 11:45 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 02:11 AM
