Wire Running Tools - Tools - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 11:11 AM   #1
Insatiable Learner
Rewards Points: 166
Question
Wire Running Tools
Lately I've been doing a lot of electrical work. A lot of times I have to run wires in tight places and I can't drill holes in the studs because there is not enough room to get a drill with a bit in there. I bought a 90 degree right angle adapter, but after drilling one hole it stopped working (gears stripped). I was thinking about buying a right angle drill but was afraid the same thing would happen.
What tool(s) do you guys use when you have to drill in tight spaces?
Smallest hole I would need to drill would be around 1/2 inch (for 14/2 wire) but they are usually 4 or 5 inches long. Does anyone sell special bits that are shorter? Thanks.
AngelArs is offline   Reply With Quote
Old 05-17-2013, 04:45 PM   #2
Oso954's Avatar
Rewards Points: 772
I think you are hung up on the idea of getting the bit and drill motor between the studs. Get a 3/4 or larger bit and a drill at an angle. In tighter spots like this, use nail plates.
Oso954 is offline   Reply With Quote
Old 05-17-2013, 08:17 PM   #3
Insatiable Learner
Rewards Points: 166
Smile
The places where I have the most problems is in ceiling headers, or where the roof meets the wall...
Old 05-17-2013, 08:26 PM   #4
Rewards Points: 13,300
Ceiling headers
You mean top plates?
A real 1/2" right angle drill and some silver and demming drills will drill in some tight spots and not strip out.
Old 05-29-2013, 09:51 PM   #5
Household Handyman
Rewards Points: 1,408
Find you an "electricians flexible drill bit", these are generally 9/16" drill bits on a 54" long flexible shaft. I know that both Lowes and HD sell these. Lowes will have the Greenlee brand. These allow you to go into a cut-out on a sheetrock wall and drill through wall studs up to the 54' length of the bit's shank. It works the same for drilling through top plates or bottom plates. I have a couple of these and when they are needed they are gold plated to me.
The Following User Says Thank You to Thurman For This Useful Post:
AngelArs (05-29-2013)
Old 05-29-2013, 11:08 PM   #6
Insatiable Learner
Rewards Points: 166
Smile
Thanks Thurman. Would you happen to have a part number? Searching for "Greenlee" shows no flexible drill bit, and searching for "flexible drill bit" comes up with 20 pages of every drill bit lowes sells.
Old 05-29-2013, 11:27 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Let me guess.....you had one of those 90 deg adapters from Harbor Freight?
Go read the thread on Ryobi tools....figure out which one you want to invest in....then start buying cordless tools of the same brand that use the same battery....
In the Ryobi 18v family I have....
2 drills
1 90 deg drill
2 5 1/4" skill saws
1 sawzall
1 hand vac
2 Lights
Corded...
Drill
planner
Table Saw
Plunge Router
And a few more power tools from other manuf.....I have 4 routers BTW....
And I'm just a DIY'r
Old 05-29-2013, 11:53 PM   #8
jproffer's Avatar
Rewards Points: 706
One of these: HERE
Sometimes sold as a kit with one of these: HERE
and one of these: HERE
I couldn't find the "kit" online, but my local stores all have them. Both Lowes and HD.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
AngelArs (05-30-2013)
Old 05-30-2013, 12:23 AM   #9
Insatiable Learner
Rewards Points: 166
Smile
THANKS jproffer, I'll pick those tools up.
Running Wire From Existing Outlet bgitler Electrical 1 08-23-2012 10:10 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Running electrical wire into 98 Buick Lasabre Red Squirrel Automotive Repairs 5 04-22-2010 10:08 AM
Running new wire in existing wall Rdakota06 Electrical 5 07-30-2009 03:57 PM
wire running question ponch37300 Electrical 4 04-21-2009 04:58 PM
