Will This Compressor Work With These Nailers? - Tools - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 10:22 AM   #1
Rewards Points: 384
Will this compressor work with these nailers?
I'm trying to find a decent(affordable) compressor that can handle both of these guns.
http://www.amazon.com/Factory-Recond...d=C535B2FOSOVA
Will this work?
http://www.amazon.com/Porter-Cable-C...5939609&sr=1-4
I'm worried that the framing gun wont work well with it. This is for light use in the house to frame some walls and some other random projects.
RyanD is offline   Reply With Quote
Old 06-25-2009, 11:10 AM   #2
Experienced goon
For light use you'll be fine. The thing is going to run a lot to keep up with you if you're framing at a good clip, but for one person it will be fine, just take breaks. I've run a 3.5" framer on a 1/4" hose, no issues, but I don't go as fast as a pro would. Not sure of the longevity of that type of compressor.
jpelzer is offline   Reply With Quote
Old 06-25-2009, 11:36 AM   #3
Oldguy
Rehabber's Avatar
That will work fine as long as your not a production framer. However I would recommend you buy a full round head nailer, not a clipped head nailer as many communities do not allow the use of clipped head nails (and they may be hard to find)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-25-2009, 01:32 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Rehabber View Post
......I would recommend you buy a full round head nailer, not a clipped head nailer as many communities do not allow the use of clipped head nails (and they may be hard to find)
Ditto here is a related thread that also admonishes against clipped head nails in MA:
Framing nailer for a small renovation
I have three compressors with my smallest being the One gallon Senco which I have used for pick-up work using a PC framing nailer.
http://www.amazon.com/Senco-PC1010-C.../dp/B0000AQK78
A pancake nailer should work fine as long as you don't use any bump nailing
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-30-2009, 11:31 PM   #5
Builder and Remodeler
JohnCarpenter's Avatar
You can use a clipped head nailer with offset round head nails. Use them all the time in my guns. Passes code and get to use paper tape - no plastic flying at my face.
That gun ad is strange, it says clipped head, but farther down the page it says full head wire weld like on the Bostitch site.
JohnCarpenter is offline   Reply With Quote
Old 06-30-2009, 11:43 PM   #6
Registered User
Rewards Points: 4,912
The oil-less compressors have Teflon rings that wear out after a year or so of production framing, and you have to rebuild them. Until then, they gradually loose the compression (leak around the rings) they had when new and it takes longer and longer to fill the tank. It may not be noticeable as I've heard many framers say-- they're great and lightweight. As stated, occasional use- ok. Be safe, G
Question about Flooring nailers all7801158 Flooring 3 05-31-2009 12:00 PM
Question about Flooring nailers all7801158 Tools 1 05-27-2009 05:23 AM
pnuematic nailers manofs Carpentry 11 01-20-2009 11:15 PM
Dewalt 18V 16G Nailers rgmetro Tools 1 07-30-2007 09:20 PM
Ceiling Nailers leted_82 Carpentry 2 04-13-2007 10:26 AM
