Wide And *flat* SDS Max Bit? - Tools - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 09:07 AM   #1
Rewards Points: 150
Wide and *flat* SDS max bit?
My standing crawl space has red brick walls between the brick pilasters - none of it was finished on the inside so there are chunks and bumps of mortar sticking out at every joint.
I have a Makita HR4002 SDS-max rotary/hammer drill which is a very capable piece of equipment, but I don't know what bit I should use to maximize productivity. I have a spade bit for clay, but the edge is rounded so you only have about an inch or so of width to work with.
There isn't a lot of mortar sticking out so I'd like to be able to knock down several beads in one pass.
Is there an SDS Max bit like a chisel but very wide, maybe 6 or 8" total width?
sheslostcontrol is offline   Reply With Quote
Old 05-02-2013, 09:07 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I'd first try one of these although it is only 3" It is designed for your application.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-03-2013, 04:00 AM   #3
Too Short? Cut it Again!
Not sure a hammer drill would be my first choice for cold chiseling mortar if I understand your intent? Would not a tuck pointing, grinding or even a compressor driven air impact chisel tool work out better?
I speak from no experience I admit. Just seems a tool mismatch to me.
Old 05-03-2013, 08:54 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Maybe if we knew what you want to accomplish, we could offer some suggestions. Champion makes a 4-1/2" scaling chisel and an asphalt cutter that is almost 5" wide.
http://www.championchisel.com/catego...sds-max-steel/
Old 05-03-2013, 01:24 PM   #5
Tool Geek
PaliBob's Avatar
My take is that the OP has a HR4002 that they intend to use for this scaling type job in the 'Hammering Only'mode.
Disclaimer
& Stay Safe
.....Bob Lavery
