Why Sawzall Blade Bent? - Tools - DIY Chatroom Home Improvement Forum
Old 10-26-2013, 10:47 AM   #1
Rewards Points: 2,238
why sawzall blade bent?
This is exhausting and I only have 1/2 of this shrub root out.
How did my blade get bent? Do I need to replace it? The teeth still look good.
I touched the blade after using it and almost got burned. I'm guessing the heat from using it and my awkward pressure made the blade bend.
There's a sewer pvc pipe just inches away so I'm trying to be very careful.
Startingover is online now   Reply With Quote
Old 10-26-2013, 10:56 AM   #2
jschaben
Rewards Points: 502
Attachment 77237
Looks like it probably hit something. I'd replace the blade with a shorter one, it doesn't look like you have enough clearance behind the root.
Unless you have a compelling need to completely remove that thing, I would just cut down lower than the surface and treat the cut end with Tordon. That will kill off the rest of the root and it will just rot away. You should be able to find the stuff at any Farm and Ranch supply place or a well stocked hardware store.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Startingover (10-26-2013)
Old 10-26-2013, 11:12 AM   #3
John,
thank you! Never heard of Tordon before but will buy some.
Old 10-26-2013, 11:15 AM   #4
kwikfishron's Avatar
Rewards Points: 1,008
Just bend it back the best that you can and try again. Yes, a shorter blade might have been better there but you should still be able to do it with what you have.
Try not to let the tip "butt into" anything, that's likely how you bent it so bad.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 10-26-2013, 11:25 AM   #5
Rewards Points: 14,312
I just use the claw part of my hammer to straighten it back out.
Using a shorter and wider blade will help.
Any by Milwaukee marked The Ax will work.
Old 10-26-2013, 03:05 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
joes, right the milwaukee blades are less resistant to bending..
that blade looks like a freud blade. ther are made of much thinner metal and are extremely easy to bend
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Startingover (10-28-2013)
Old 10-26-2013, 03:12 PM   #7
If you have never bent a sawsall blade before you must have never used a sawsall before. Happens all the time.
There tough, beat them back into shape and keep on going.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
raylo32 (10-26-2013), roofermann (11-23-2013), Startingover (10-28-2013)
Old 10-28-2013, 12:00 PM   #8
Dave88LX's Avatar
Rewards Points: 566
Ah, don't touch the blade. Friction and stuff. They get hot.
Dave88LX is offline   Reply With Quote
The Following User Says Thank You to Dave88LX For This Useful Post:
Old 10-28-2013, 05:01 PM   #9
Good deduction, I've never used one before. It did the job altho it does scare me a little when it's going fast.
These are Diablo blades, the only pruning blade in H.D. When this pk is gone I'll know what to look for next time.
A few sore muscles today from applying pressure so waiting awhile before tackling the next root to come out.
Old 10-28-2013, 05:46 PM   #10
Rewards Points: 2,078
Do your body a favor, trash that blade and replace with new. If you think that saw jerks your joints around from not having the shoe against the tree with a new blade that has too little tooth set for wood, you won't last very long with that snake blade pinching in the kerf hundreds of times / minute.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Startingover (10-29-2013)
Old 10-29-2013, 05:32 AM   #11
DIY staff
Rewards Points: 7,174
I like Milwaukee blades---and use shorter ones for roots--usually a 5 inch wood cutting blade.
A pruning blade is to delicate for roots---use a regular wood cutting blade---
Old 10-29-2013, 10:53 AM   #12
Got a second root out in record time. It was a breeze. Makes a big difference if you have plenty of space to work. Yesterday I was working in a tight spot between a sidewalk and pvc pipe and couldn't dig far enough down to get a good angle.
appreciate all the advice on blades. I've saved more than enough money doing this work myself, to pay for my saws. It's a good feeling. And I didn't have to go to a boring gym, like my girlfriends, to get a workout.
Old 10-29-2013, 11:05 AM   #13
[QUOTE=Startingover;1259591. It's a good feeling. And I didn't have to go to a boring gym, like my girlfriends, to get a workout.[/QUOTE]
Awesome!!
Plus its very empowering to do it yourself !!
Next...go buy a sledge and get to wacking the pesky wall you wanted down. You will feel amazing.
For gawds sake make sure its not load bearing first.
You know I only meant that job as an example, but we know you are capable of doing whatever improvement you think needs doing..
creeper is offline   Reply With Quote
The Following 2 Users Say Thank You to creeper For This Useful Post:
oh'mike (10-29-2013), Startingover (10-29-2013)
Circular Saw - Blade Plug Problem ejseidman Tools 7 10-01-2012 01:04 PM
Best Tools for Drywall Removal? neo95gt Drywall & Plaster 59 12-27-2011 12:44 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
Sawzall with Remgrit blade for cutting cement board Proby Carpentry 7 08-08-2010 04:47 PM
