Who Owns Milwaukee Now - Tools - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 02:41 AM   #1
Who owns Milwaukee now
Who owns Milwaukee now?
hvaclover is offline   Reply With Quote
Old 11-24-2010, 04:39 AM   #2
Chicago, IL
Michael Thomas's Avatar
Techtronic Industries Company Ltd. of Hong Kong
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-24-2010, 05:09 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Michael Thomas View Post
Techtronic Industries Company Ltd. of Honk Kong
Sad, Sad, Sad
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-24-2010, 08:07 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 536
They use to be really good tools but I don't know now. I never did like their battery powered drill though, the batteries were just not very good.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-26-2010, 02:00 AM   #5
i have all older Milwaukee cordless and corded drills and sawzalls, probably pushing ten years now, and i want to buy new stuff cause that is part of the fun of being in a trade: Buying the latest and coolest tool to come on the market.
But now I doubt I will buy anything new cause since they are not made here anymore it takes all the fun out of it.
This is not meant to offend anyone as I am only making this observation about any trade except my own.
I am seeing a trend in the younger age brackets of my trade of guys who don't even give a damn that they are buying import tools. Even if Dewalt and other American brands aren't made here (like you guys said Milwaukee is Chinese owned so they don't even count as an American company any more) at least some of the money comes back here to support what ever American jobs those companies have in admin and design jobs.
When you call them on it they just don't give a damn if it's even just an American name.
Maybe I am falling behind and just too old...
Do you guys suppose I am worrying over nothing?
Old 11-28-2010, 02:55 PM   #6
Tizzer's Avatar
Rewards Points: 460
Yes. My now Chinese owned Milwaukee cordless drill still works great. So does my Chinese owned Sanyo television set.
Tizzer is offline   Reply With Quote
Old 11-29-2010, 02:03 AM   #7
No apologies. I fought them first hand.
Old 11-29-2010, 10:30 PM   #8
No worries with the import stuff at work. They seem to hold up well enough compared to modern American-made stuff; the bigger names, at least. The most enjoyment I have now is in scouring local pawn shops in search of old tools that were made locally (in my case, in Canada). The old, built-to-last, indestructible stuff. I bring them home, clean them up, and put them to good use in my DIY projects.
Recently found an old jigsaw, from back before they were even called jigsaws (sabre saw, the label says). Made in Canada for the Eaton company (now defunct), an entry-level model at the time, but the gears have real sharp teeth still, the grease was still good, motor runs quietly, and the whole thing is inside a thick aluminium case. I will have much fun with this baby. It's older than I am.
Squishy is offline   Reply With Quote
Old 11-30-2010, 12:54 AM   #9
Rewards Points: 382
We still are, it is an economical war now and we are losing.
fireguy is offline   Reply With Quote
Old 11-30-2010, 01:47 AM   #10
Canada made some damn good stuff tools included. I have a fifty year old Monkey Wards Craft Master 3/4" industrial drill---all metal body with a ground added. Works great as a back up for going thru foundation wood plates.
I just don't use it in the rain cause it gives a little bit of a shock. Even works off DC for factories that don't have 110volts.
I have a Milwaukee Hole Hawg that hit a nail and broke. Been broke since '04 I think. So it's been either the Craft Master or the De Walt 24volt cordless for punching line-set holes in walls.
Old 12-12-2010, 10:48 PM   #11
Chinese merchandise has improved greatly. However, I prefer many of the older US made products like US made drills and hand tools because they are better. The Chinese materials are often of an inferior quality and the hand machining is not there. The consistency is not there. The quality may sometimes be nearly comparable but that is not the real problem. We got started buying Chinese goods because they were cheap but that is no longer the case. Tires at Sam's club were only $10 cheaper for Chinese made compared to US. Both had US company names. Milwaukee drills are some of the most expensive in the store although they are Chinese like Ryobi and Sears drills. If the prices are the same, why buy Chinese? Because we no longer have a choice. I have Ryobi drills that have held up to abuse but they were much cheaper than Milwaukees and have cheaper batteries. The point is the Chinese are driving US companies out of the market with cheap goods and then moving on to replace premium US manufacturing with their own at the old premium prices. They are destroying American industry and American jobs. If Chinese labor is so cheap, why are their goods, like Milwaukee drills and US branded tires so expensive. Is it because the US companies are selling out American labor while pocketing higher profit with essentially the same prices we had with US manufactured goods? When the Chinese are done they will charge what they want because they will make all the goods in all the price ranges. US competition barely exists. And, as someone said, younger people will never know the difference. Of course, the 10% unemployed will eventually figure it out but too late. What country can compete in the world with a constantly shrinking manufacturing sector?
psyker99 is offline   Reply With Quote
Old 12-13-2010, 01:54 AM   #12
AAARRGGGHHHH you hit my Hot Button!
I had a conversation with a Fielf Piecec HVAC meter designer. He told me that the higher cost to manufacture on US soil shows no benefit.
He didn't say the quality was a problem, just no benefit. Ok They went to China to save labor....how come we are still paying high dollar if they have a labor cost advantage in China. The Fieldpiece guy never answered.
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 01:10 PM
Milwaukee Airless/ Fine Finish Paint Sprayer (good or bad?) ehoez Painting 3 10-09-2010 01:56 AM
Milwaukee sawzall problem. pkwon5@ Tools 6 02-11-2009 02:54 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 12:41 PM
Milwaukee Thermoflo Furnace Filter? HELP! ur1ofus HVAC 1 12-02-2007 04:57 PM
