Where To Get U Shaped Propane Torch - Tools - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 06:50 AM   #1
Rewards Points: 1,514
Where to get U shaped propane torch
I am looking for a U shaped propane torch. This is because the work is at or below floor level and with a conventional torch the tank is angled down to point at the work and spills liquid propane while with a U shaped torch I can reach the work and the tank is still angled up.
Old 03-27-2011, 06:58 AM   #2
Experienced
Jackofall1's Avatar
Would not a U shaped torch just heat up the hand that was holding it?
Mark
Old 03-27-2011, 07:27 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I think you can still get a soldering outfit at the HD that has a long (about 36") flexible hose from the tank to the torch.
Andy.
AndyGump is offline   Reply With Quote
Old 04-03-2011, 07:21 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
u mean like this??
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Torch down info sjacobso Roofing/Siding 8 07-24-2012 02:54 PM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 09:21 AM
Coating over torch down before new decking bobhpete Roofing/Siding 2 05-17-2008 08:39 PM
Propane heating questions Badfish740 General DIY Discussions 1 09-25-2007 07:46 PM
