What's The Proper Name For A Flat Skinny Wrench - Tools - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 05:53 AM   #1
Rewards Points: 248
what's the proper name for a flat skinny wrench
I am trying to adjust a retaining nut that has a jam nut next to it. Their combined width is that of standard hex nut. I need a thin flat wrench. Is there a proper name for that kind of wrench?
diy888 is offline   Reply With Quote
Old 11-04-2012, 06:46 AM   #2
DIY staff
Rewards Points: 7,174
Thin wrench open ended got lots of info----Thin Wrenches from Sears.com
Thinwrench | Custom Thin Wrenches
For a one time special use----consider simply grinding an old wrench until it fits----
If you have a grinder---and a junk wrench----that would save you a search and get the job done ---
Old 11-04-2012, 07:46 AM   #3
Rewards Points: 248
Thanks for the links and suggestions. Could be "tappet wrench" is what I want to search for --a lot of "flat" wrenches look pretty thick to me. They seem to be for suited more for narrow places than for half-thickness jam nuts.
Old 11-04-2012, 08:01 AM   #4
DIY staff
Finding thin wrenches has always been a problem for me----I lost a colet wrench for one of my routers
Big thing---I never have replaced it----for smaller wrenches I just grind down a junk wrench---If you don't have a bench grinder--you will need to search out a set of thin wrenches.
Old 11-04-2012, 01:53 PM   #5
(the original)
Rewards Points: 756
Cup and cone hub on a bicycle, or something similar? Park Tools, or Pedro's for thin cone wrenches 13mm and up. If you need SAE, the only ones I know of these days are the Zog's Mike linked.
If you have a scroll saw, it's not hard to make your own from 2mm flat stock.
ratherbefishin' is offline   Reply With Quote
Old 11-04-2012, 06:12 PM   #6
Davejss's Avatar
Rewards Points: 772
Shelly Duvall. Oh, you said WRENCH. My bad...
Davejss is offline   Reply With Quote
Old 11-05-2012, 04:05 AM   #7
Rewards Points: 248
Old 11-05-2012, 04:13 AM   #8
Rewards Points: 248
SAE.
It's an old drill press from the 1930s -- the quill spring housing is held to the head casting with the two half-height nuts: retaining nut and jam nut.
Old 11-05-2012, 06:33 AM   #9
Rewards Points: 1,258
When in a jamb with jamb nuts, consider drilling a shallow hole in two flats 180 apart and then use a hammer and punch in the holes to set the nut working alternate sides.
Old 11-05-2012, 09:04 AM   #10
Rewards Points: 2,212
cut/grind your own out of 1/4" metal plate.
mae-ling is offline   Reply With Quote
Old 11-05-2012, 01:34 PM   #11
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I vote for Shelly
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-05-2012, 07:34 PM   #12
Missouri Bound's Avatar
Unless space is an issue, replace the jam nut with a full sized nut. And I vote for "slim wrench"
Do you want it your way or the right way?
Old 11-07-2012, 12:28 PM   #13
Rewards Points: 131
They are called tappet wrenches, for automobile/general use. Cone wrenches when designed specifically for bicycle work. Some cone wrenches have very large heads, like for bottom bracket or headset use.
Like said above though, no need to seek them out, just get a sacrificial "regular" wrench in the proper size and grind that bad boy down to the needed thickness.
Chokingdogs is offline   Reply With Quote
The Following 2 Users Say Thank You to Chokingdogs For This Useful Post:
oh'mike (11-07-2012), Thurman (11-24-2012)
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 04:16 PM
Flat paint help in apartment cnj419 Painting 4 02-24-2011 07:07 PM
replace old flat roof diyer2010 Roofing/Siding 0 12-22-2010 03:00 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
