what's the proper name for a flat skinny wrench
I am trying to adjust a retaining nut that has a jam nut next to it. Their combined width is that of standard hex nut. I need a thin flat wrench. Is there a proper name for that kind of wrench?
Thin wrench open ended got lots of info----Thin Wrenches from Sears.com
Thinwrench | Custom Thin Wrenches For a one time special use----consider simply grinding an old wrench until it fits---- If you have a grinder---and a junk wrench----that would save you a search and get the job done --- |
Finding thin wrenches has always been a problem for me----I lost a colet wrench for one of my routers
Big thing---I never have replaced it----for smaller wrenches I just grind down a junk wrench---If you don't have a bench grinder--you will need to search out a set of thin wrenches. |
If you have a scroll saw, it's not hard to make your own from 2mm flat stock. |
Shelly Duvall. Oh, you said WRENCH. My bad...
It's an old drill press from the 1930s -- the quill spring housing is held to the head casting with the two half-height nuts: retaining nut and jam nut. |
When in a jamb with jamb nuts, consider drilling a shallow hole in two flats 180° apart and then use a hammer and punch in the holes to set the nut working alternate sides.
cut/grind your own out of 1/4" metal plate.
I vote for Shelly
They are called tappet wrenches, for automobile/general use. Cone wrenches when designed specifically for bicycle work. Some cone wrenches have very large heads, like for bottom bracket or headset use.
Like said above though, no need to seek them out, just get a sacrificial "regular" wrench in the proper size and grind that bad boy down to the needed thickness. |
| All times are GMT -4. The time now is 05:35 AM. |
