Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-10-2008, 09:19 PM   #1
Whats a good Concrete Mixer ?
whats a good Concrete Mixer for a light residental projects? (DIY, not commercial use)
Any good recomendations for one under $200, and another one for under $500?
i saw one at northern tool for like $179 (here: http://www.northerntool.com/webapp/w...6929_200356929 )
dint know if it would be too weak to do any real work..
ehoez is offline   Reply With Quote
Old 06-11-2008, 05:33 PM   #2
anyone? thanx
Old 06-11-2008, 07:46 PM   #3
A wheelbarrow and a hoe are better than a 200 buck concrete mixer.
Tscarborough is offline   Reply With Quote
Old 06-26-2008, 01:58 PM   #4
anyone else care to comment?
Old 06-26-2008, 03:41 PM   #5
It would help if you listed some things you're planning in order to receive recomendations. Personnally, I would rent one for those infrequent times it would be needed. I've been in the remodeling business for thirty years and have only used one once, last week. I mixed up 2000 lbs for a small set of stairs in a little over an hour and a half. I hand mixed another 2000lbs to set some Belgian block. I used a tub and a hoe as the task reqiured more time to set the stone.
Ron
Old 06-26-2008, 05:16 PM   #6
Ron
i would rent one, but they are $40 a DAY here..
i prefer to OWN my own tools..
i want to make a driveway (about 100feet by 12 wide) and a few patios (like 12x12 slabs) and other misc projects..
so even if i have to spend $400 or $500, its much cheaer to own
just wanted to know what ones to stay away from
Old 06-26-2008, 05:30 PM   #7
General Contractor
MacRoadie's Avatar
The $400 to $500 ones....
On a serious note, the only mixer you'll get in that price range will likely be a small 5 CF drum model. If you take your driveway as an example, 100' x12' is going to be somewhere in the 15 CY range at 4" thick and 22 CY at 6" thick. 15 CY would calculate out to 81 loads in your little mixer, and the 6" drive would be nearly 120 loads.
MacRoadie is offline   Reply With Quote
Old 06-26-2008, 06:10 PM   #8
The patios are in the range of a portable mixer. The driveway might be if you have some(alot of) help. Personnally, I would order a truck or two and lay the cement and then you could finish it, assuming you have the skill set.
I used a Husky rented at Home Depot. You could mix 400 lbs of product per batch.
Ron
Old 06-26-2008, 07:42 PM   #9
You will be hard pressed to do a 12x12, much less a driveway with a pissant mixer like that. Better to buy it from a truck or rent.
I (we) have poured 6 CuYds in one day with a 3CuFt mixer, but it was grouting walls, with no concern for finishing, which will be the limiting factor on anything more than a yard or so.
Old 06-27-2008, 12:19 PM   #10
I bought this mixer the other day.
http://www.amazon.com/Heavy-Duty-Whe...4582607&sr=1-1
It seems pretty sturdy. I'm using it to fill post holes one at a time. You're not going to pour a slab with it though, unless you have four guys working really fast. From what I read about other mixers count on it breaking if you put any kind of stress on it, ie. more than one bag at a time.
ovahimba is offline   Reply With Quote
Old 06-27-2008, 01:00 PM   #11
Any more help than three guys with that little mixer is a waste of manpower. The limiting factor is the mixer cannot mix enough, quickly enough before the concrete is unworkable on the larger exposed projects.
47_47 is offline   Reply With Quote
Old 06-29-2008, 04:25 PM   #12
5 gallon bucket and a paddle to attach to your electric drill
dstill is offline   Reply With Quote
More On This Topic
There are a few tools that you’ll for performing preventative motorcycle maintenance on your motorcycle; use the checklist and tips found on this free video. Read More »
About DIY Plumbing
About DIY Plumbing by Shawn Kenny
Before tackling plumbing problems at home, make sure to get the proper tools and mindset for the job at hand. Avoid making huge mistakes when fixing plumbing issues without professional assistance with help from a plumber and HVAC tech in this free video... Read More »
DIY Halloween Decorations
DIY Halloween Decorations by expertvillage
Want to save money on Halloween decorations? Learn do it yourself ideas for indoor Halloween decorations in this do it yourself Halloween decorations video. Read More »
DIY Home Security Tips
DIY Home Security Tips by expertvillage
Learn how to protect your personal properly against theft in this free video clip from an expert locksmiths. Read More »
Buy pretreated wood to withstand weather related conditions for outdoor DIY (do-it-yourself) projects. Purchase lumber with tips from a home repairman in this free video on home improvements. Read More »
concrete from mortar Wahoo Building & Construction 14 03-08-2008 12:15 AM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 09:10 AM
thickening the consistency of concrete & does aerated concrete come in a powder artist1 General Discussion 7 02-28-2007 10:09 PM
Reinforce concrete piers? Neil_K Building & Construction 8 11-21-2004 07:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
