What's The Best Mobile Base For A Table Saw? - Tools - DIY Chatroom Home Improvement Forum
Old 08-20-2008, 09:58 AM   #1
RDS
Rewards Points: 150
What's the best mobile base for a table saw?
Trying to get the saw (Delta 36-390C) more mobile. I see that Delta, HTC and Rockler all have universal mobile bases for around 60 bucks plus the cost of hardwood rails. Anyone have good/bad experiences with these products they'd be willing to share? Thanks in advance.
RDS is offline   Reply With Quote
Old 08-20-2008, 11:58 AM   #2
RippySkippy's Avatar
I couldn't find the picture for the saw model you mention, but I have a Delta contractors don't know the model number, and it had a steel mobile base to fit the saw, you could check your local service center. I have both the one from Delta for the saw, the universal where you build the rails, and they are for all intents and purposes, the same in function, the one from Delta is a bit more compact. FYI the universal stand from Rockler is nearly identical to the one from Delta, and if you watch...they'll be on sale every now and again for around $39 or so. FWIW, I like the Delta style where everything is done with your foot, some have a knob with a threaded rod to lower the supports to the floor.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 08-20-2008, 12:27 PM   #3
RDS
Rewards Points: 150
Sorry, it's also called the TS300 (picture here):
http://www.amazon.com/Delta-TS300-Sh.../dp/B00006JZZL
(I think 36-390C is what they call it in Canada, where originally purchased.)
Thanks for the tip about the Rockler -- I will look out for sales.
Old 08-20-2008, 02:43 PM   #4
47_47's Avatar
Rewards Points: 74
I've got a HTC 1000 from Rockler a few years ago. Works good, but I only need to move the saw when I need to rip 16' material.
47_47 is offline   Reply With Quote
Old 10-14-2008, 04:04 PM   #5
RDS
Rewards Points: 150
Thanks RippySkippy
I took your advice and waited for the Rockler base to go on sale, then grabbed it. Seems like it'll do the trick.
Old 10-15-2008, 08:54 AM   #6
Your welcome. I think you'll like it...they're well made.
LMASD
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 06:42 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 07:44 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 06:38 AM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
