What Will It Take To Repair This Grex Pinner - Tools - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 03:27 AM   #1
Rewards Points: 866
What will it take to repair this Grex pinner
I am looking at buying a used Grex p630 micropinner on Ebay. The seller says
[quote}THE PLUNGER TIP WILL NEED TO BE SERVICED - AS THE VERY TIP BROKE. THIS IS A COMMON THING WITH PINNERS, BUT CAN BE EASILY FIXED BY SENDING IT IN OR BRINGING IT INTO A LOCAL REPAIR SHOP - WHERE AIR TOOLS ARE SOLD **
Other than this, I tried grinding a little on the very tip, so it would countersink better, but a new plunger would work well and bring it back into good working order.[/quote]
Any idea how much of a problem this is or how much it would cost to have it repaired. Does having trouble counter sinking suggest it may need a rebuild, such as o rings. I think the tip broke because it was weakened by being ground down. I don't need a gun I can rely upon for work, but just for occasional home projects and if repairs are simple enough I will buy the parts and do it. Or is he talking about a bad driver and a bad safety plunger? Anyone have an idea what this is worth as is? Thanks
Klawman is offline   Reply With Quote
Old 03-08-2010, 12:09 PM   #2
Rewards Points: 866
I got better info on the pinner. What it needs isn't so much a safety device, but a piston ram assembly (what I call the driver). At a minimum, I will have just less than $60 into this, and that is if the nose and nose plate, both of which were ground down, don't need replacement. If they do, that is $24 a piece. The safety device that is missing is some sort of double trigger behing the main trigger. Pass?
Old 03-09-2010, 12:13 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... I'd love to tryin' Help,.. But I have No idea what you're talkin' about....
Old 03-09-2010, 01:12 PM   #4
Rewards Points: 866
Sorry for the confusion. I am trying to figure out if it worth buying this used pinner off of ebay. Here is a link to its description. http://cgi.ebay.com/GREX-Headless-Ai...item35a7b012a0
I have emailed the seller and provided him with a Grex parts list and schematic to attempt to clarify what is wrong. It is available on the net in pdf by clicking http://grexusa.com/grexusa/downloads...P630_R01.0.pdf
That runs $28 plus tax and shipping. The piston drive assembly, more commonly called the "driver", definitely needs to be replaced.
From what the seller says, it isn't clear that one or both pieces of the nose don't need replacement. The bottom piece, called the guide plate' is $29 and the upper piece, which is the nose cover plate, runs $25. That is without tax and shippping. Those are nos. 42 and 43 on the schematic.
I wouldn't be surprised if it needs a set of 0'rings for another $15.
I am thinking if the nose cover plate and the guide plate (nose) are bad, I am better off with a cheap new pinner for light duty diy use. If it fails, toss it.
Then I learned that a spring behind the trigger, which requires the trigger to be pressed twice to fire, has been removed.
Old 03-09-2010, 05:37 PM   #5
DIY staff
Rewards Points: 7,174
Sounds like a pig in a poke.--I'd pass on that one.
Old 03-09-2010, 05:46 PM   #6
Rewards Points: 866
Thanks Mike. When detailing the potential problems, it seemed all the more like a pig with lipstick and I was wondering why I even considered it. I will pass.
Old 03-09-2010, 06:08 PM   #7
DIY staff
The Harbor freight pinner is a disappointment--I borrowed one once.
I have heard that Porter cable makes a respectable one.
Of course Grex is mighty fine(until it falls into the hands of a fool) HaHa--Mike--
Old 03-09-2010, 07:58 PM   #8
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Smile
I have the PC PIN100. Works great with pins from 1/2 to one inch, no problems.
http://www.amazon.com/Porter-Cable-P.../dp/B00006411F
The criticism I have heard about Grex or other brands that shoot those headless pins up to 2" long is that when shooting long pins in hardwood the pins sometimes curl in the grain and come out where they are not supposed to.
When you get a Pinner, make sure you load the pins with the arrows pointing down or you will get jams.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-09-2010, 08:13 PM   #9
Rewards Points: 866
Hi Bob. I agree with you on long pins, which is why I went with the 15 Gauge over a 16 Gauge finish nailer, both of which shot up to 2-1/2" pins, back then for hanging crown moulding.
Tags
23 gauge pinner , micro pinner
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 09:43 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 02:02 AM
