-   Tools (http://www.diychatroom.com/f29/)
-   -   What will it take to repair this Grex pinner (http://www.diychatroom.com/f29/what-will-take-repair-grex-pinner-66263/)
Klawman 03-08-2010 02:27 AM
I am looking at buying a used Grex p630 micropinner on Ebay. The seller says
[quote}THE PLUNGER TIP WILL NEED TO BE SERVICED - AS THE VERY TIP BROKE. THIS IS A COMMON THING WITH PINNERS, BUT CAN BE EASILY FIXED BY SENDING IT IN OR BRINGING IT INTO A LOCAL REPAIR SHOP - WHERE AIR TOOLS ARE SOLD **
Other than this, I tried grinding a little on the very tip, so it would countersink better, but a new plunger would work well and bring it back into good working order.[/quote]
Any idea how much of a problem this is or how much it would cost to have it repaired. Does having trouble counter sinking suggest it may need a rebuild, such as o rings. I think the tip broke because it was weakened by being ground down. I don't need a gun I can rely upon for work, but just for occasional home projects and if repairs are simple enough I will buy the parts and do it. Or is he talking about a bad driver and a bad safety plunger? Anyone have an idea what this is worth as is? Thanks
Klawman 03-08-2010 11:09 AM
I got better info on the pinner. What it needs isn't so much a safety device, but a piston ram assembly (what I call the driver). At a minimum, I will have just less than $60 into this, and that is if the nose and nose plate, both of which were ground down, don't need replacement. If they do, that is $24 a piece. The safety device that is missing is some sort of double trigger behing the main trigger. Pass?
Bondo 03-09-2010 11:13 AM
Ayuh,... I'd love to tryin' Help,.. But I have No idea what you're talkin' about....
Klawman 03-09-2010 12:12 PM
Sorry for the confusion. I am trying to figure out if it worth buying this used pinner off of ebay. Here is a link to its description. http://cgi.ebay.com/GREX-Headless-Ai...item35a7b012a0
I have emailed the seller and provided him with a Grex parts list and schematic to attempt to clarify what is wrong. It is available on the net in pdf by clicking http://grexusa.com/grexusa/downloads...P630_R01.0.pdf
That runs $28 plus tax and shipping. The piston drive assembly, more commonly called the "driver", definitely needs to be replaced.
From what the seller says, it isn't clear that one or both pieces of the nose don't need replacement. The bottom piece, called the guide plate' is $29 and the upper piece, which is the nose cover plate, runs $25. That is without tax and shippping. Those are nos. 42 and 43 on the schematic.
I wouldn't be surprised if it needs a set of 0'rings for another $15.
I am thinking if the nose cover plate and the guide plate (nose) are bad, I am better off with a cheap new pinner for light duty diy use. If it fails, toss it.
Then I learned that a spring behind the trigger, which requires the trigger to be pressed twice to fire, has been removed.
oh'mike 03-09-2010 04:37 PM
Sounds like a pig in a poke.--I'd pass on that one.
Klawman 03-09-2010 04:46 PM
Thanks Mike. When detailing the potential problems, it seemed all the more like a pig with lipstick and I was wondering why I even considered it. I will pass.
oh'mike 03-09-2010 05:08 PM
The Harbor freight pinner is a disappointment--I borrowed one once.
I have heard that Porter cable makes a respectable one.
Of course Grex is mighty fine(until it falls into the hands of a fool) HaHa--Mike--
PaliBob 03-09-2010 06:58 PM
1 Attachment(s)
I have the PC PIN100. Works great with pins from 1/2 to one inch, no problems.
http://www.amazon.com/Porter-Cable-P.../dp/B00006411F
The criticism I have heard about Grex or other brands that shoot those headless pins up to 2" long is that when shooting long pins in hardwood the pins sometimes curl in the grain and come out where they are not supposed to.
When you get a Pinner, make sure you load the pins with the arrows pointing down or you will get jams.
Klawman 03-09-2010 07:13 PM
Hi Bob. I agree with you on long pins, which is why I went with the 15 Gauge over a 16 Gauge finish nailer, both of which shot up to 2-1/2" pins, back then for hanging crown moulding.
