What Tool Do I Use For This? - Tools - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 07:18 AM   #1
Rewards Points: 31
what tool do I use for this?
I'm finishing my basement and almost done drywalling. I'd like to install doors next but I don't know what tool to use to remove this bottom plate. See picture. I did not see this coming during framing, the wall is about 1" from the wall/pink insulation and not enough room to push/pull a wood saw to cut the plate. However, I did cut half way through the lower part of the bottom plate during framing so I only have to cut half of it from the top. I'm thinking of buying a $99 Oscillating Dremel but if there is another tool I can use for much cheaper I'll take it. Don't want to spend that much money only for this, the other door openings are OK. Besides, I read bad reviews of the Dremel tool, expensive blade replacement, blades get dull easily, etc.
Thanks.
kupalino is offline   Reply With Quote
Old 02-16-2010, 08:58 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 688
I bought the $40 eBay (Harbor Freight) version of the Fein Multimaster / Dremel Multi-Max. If you're only going to use it once, $40 is probably still too much.
You might be better off to cut it with a sawzall / reciprocating saw. It might not be as nice of a cut as you'd get with an oscillating tool, but will get the job done. I don't think an oscillating tool blade would last too long cutting through a treated stud.
Outside of powertools, if you can't saw it with a regular saw, what about a pull-saw?
Example:
http://www.google.com/products/catal...226&sa=title#p
It will definitely take some effort/time to cut through a stud with one of those, but is cheaper.
hyunelan2 is offline   Reply With Quote
Old 02-16-2010, 10:17 AM   #3
47_47's Avatar
Rewards Points: 50
Maybe I'm missing something, but what is the purpose of this door with the insulation preventing pass through? I'd use a reciprocating or a hand saw and cut it close to the concrete and finish with a bad chisel.
47_47 is offline   Reply With Quote
Old 02-16-2010, 12:04 PM   #4
Too Short? Cut it Again!
If got a Fein multimaster I bought for one specific purpose years ago before they advertised all over television. It is, hands down, the best single tool purchase I have ever made and I use it more than just about anything else for things I never dreamed I would. I love the thing. Well worth $400 or so or whatever I paid for it. It save so much time.
I don't know about the Craftsman, Dremel, Rockwell and no doubt other brand name versions of the tool. People on this site, with some minor hesitation, have been giving the Harbor Freight thing for $40 or whatever great reviews FOR WHAT IT IS at the price point. I would be tempted to give the thing a try. The Fein blade costs are killer and on recommendation from people on this site, I am going to try a few of the HF versions just for fun.
Use the HF thing for this project and others until it fails. Toss it when it burns out or breaks and buy a Fein if you find yourself using it as much as I bet you will! Or buy nine more for the cost of a Fein.
A reciprocating saw will also work but the things are so clunky and tear everything around them up a bit.
Old 02-16-2010, 12:45 PM   #5
Rewards Points: 31
47_47, this door opens to a control panel, where electricity comes in. The cement wall goes up to knee high then 2x4s from there to ceiling.
Thanks, to all replies. I have asked around at work and one suggested to just use chisel, which was my original plan. If it does not work, then buy an oscillating tool.
Old 02-16-2010, 02:40 PM   #6
47_47's Avatar
Rewards Points: 50
Fair enough. Instead of a door, why don't your just screw in an access cover?
Old 02-16-2010, 03:03 PM   #7
Household Handyman
Rewards Points: 1,408
IF you have a chisel, and IF you have a drill and bits--drill holes in the piece to be removed close enough to facilitate pulling the board out, then finish with the chisel. I'll never say that area won't be seen--but probably won't be noticed. David
Old 02-16-2010, 03:11 PM   #8
Rewards Points: 31
Thurman, that is exactly what my coworker said, use 3/8 drill bit and chisel.
Thanks.
Old 02-16-2010, 04:04 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
just get a short wood cutting blade for your sawsall put a pc of ply or hardboard to protect the foam
Tom Struble is offline   Reply With Quote
Old 02-16-2010, 07:33 PM   #10
Safe, Most of the Time!!
brokenknee's Avatar
If you already cut half way through, a hand saw would be all that is necessary. You would not need the chisel.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 02-17-2010, 02:47 PM   #11
I sell power tools & I'd suggest drill & chisel it out. No need to spend the money for something your going to do once. If you really plan on spending the cash for "ease of use" I'd go with the Dremel. Tons of attatchements, so you can likely find another use for it. A receip saw might be nice.. but tend to be a bit to big and aggressive.
gL
Life is offline   Reply With Quote
Old 03-02-2010, 06:57 AM   #12
Tool Cop
Example:
This is what I'd go with... a pull saw seems like a cheap way to go.
TrafficCopSmith is offline   Reply With Quote
Old 09-02-2010, 01:41 PM   #13
Pull saw. Based on your picture it should only take you a few minutes to work your way through that board. Buying even a P.O.S. HF throw away tool doesn't make sense here.
FLORIDADIYDAD is offline   Reply With Quote
Old 09-02-2010, 09:42 PM   #14
Registered User
Rewards Points: 5,466
7 months ago, I hope it's cut......... Welcome to the forum, FL!
Gary
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 06:02 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 12:41 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 12:34 AM
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 11:39 AM
