Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-22-2005, 12:51 PM   #1
What to look for in a Pressure Washer ?
Looking to buy a pressure washer. My first project is to get at my disgusting brick walls around the first floor. What should I consider besides psi ? brand name ?, etc.
Any info would be appreciated
Thanks,
Scott
Scott_K is offline   Reply With Quote
Old 06-22-2005, 08:30 PM   #2
Painting Contractor
Humble Abode's Avatar
check out >this< from the contractor forums.
Humble Abode is offline   Reply With Quote
Old 06-27-2005, 10:21 AM   #3
Thanks for the link ....looks like a lot of research for me.
Old 06-27-2005, 09:15 PM   #4
Thanks,
Scott
I bought one last year from HD for about $160.00 it is made by Husky and it is electric and the psi is 1650. It is great for around the house but it is a toy compared to what the pro's use. So, I guess it comes down to what you want it for.If you are going to venture out to make some cash with it, buy the best one you can afford.
plumguy is offline   Reply With Quote
Old 06-28-2005, 11:03 AM   #5
Yeah, I've been looking here and there at the consumer level washers as I'm planning to do the brick on the house and probably the driveway every now and then. I don't think I need a "Pro" level washer, but I do like to buy toyz that are overkill.:D
Old 07-03-2005, 02:43 PM   #6
Pressure washing is not always about the amount of pressure you use. It's more about the Gallons Per Minute (GPM) and the proper chemicals/detergents. 3000 psi is more than sufficient for most jobs with detergents. Spraying brick with Oxalic Acid works wonders. Many times we don't even need a pressure washer to clean a lot of our properties. Hypochlorite is the active ingredient in bleach and chlorine which works wonders as well depending on the type of stain. You can get chlorine from a pool supply store in 2 gallon containers for cheap (about $1/Gal). Anything black or green can usually be taken off with chlorine unless it's oil based. Anything red or real difficult to remove can be taken off with Oxalic including many oils. You have to let both of these chems dwell for at least 10 minutes before cleaning off. Use lots of water! http://www.thegrimescene.com is a great forum to learn - it's for contractors but if you need specifics, you'll find them there for sure.
Good luck guys!
meiersenterprises is offline   Reply With Quote
Gas Powered Pressure Washer handy man88 Tools 1 04-26-2008 08:41 AM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
