What Kind Of Pipe Clamps And Tools Are These? - Tools - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 09:50 AM   #1
What kind of pipe clamps and tools are these?
Trying to identify these tools that came in a kit.
Do they do anything besides hold/clamp? (Obviously there's a file too.)
Any ideas what that missing tool is?
Are there better tools on a budget? (I have a basic cutter, not shown, that's supposed to do PVC and EMT. I don't see how or why to use a clamp with that cutter.)
Thanks.
Puzzles is offline   Reply With Quote
Old 01-29-2012, 09:56 AM   #2
Experienced
Jackofall1's Avatar
The clamp as you call it, is actually a flaring tool, used in conjunction with the piece to the left. Don't know what is missing though.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Puzzles (01-30-2012)
Old 01-29-2012, 10:06 AM   #3
Thanks. How about the item in the middle? Does it compress/crimp or anything? I think the kit was supposed to adapt and cut.
Old 01-29-2012, 10:08 AM   #4
Experienced
Jackofall1's Avatar
It cuts tubing up to I believe 1" copper
Old 01-29-2012, 08:37 PM   #5
Rewards Points: 212
If by "the item in the middle" you mean the the tool that is in the front of the tray as pictured, that's part of the flaring tool.
You clamp the end of the tubing in the clamp thingy on the left with the various sized holed, they you hook the legs around the clamp so that the cone is pointed down the end of the tube, then you turn the threaded handle so that the cone is forced into the end of the tube, making the flare.
edit: look at the picture posted by Jackofall1, it shows how the two parts of the flaring tool fit together.
If you're asking about the tool in the center, between the faring tool and the file, that's a tubing cutter for copper tubing (a good quality one will also cut steel). one side of the opening has rollers and the other side has a sharp wheel. You put the tubing in the opening and close it down by turning the knob, then you rotate the tool around the tubing and the wheel cuts the tubing. You have to repeat this several times, tightening it a little each time, and it cuts the tubing in two.
Here's a video of how the tubing cutter works
Here's how the flaring tool works
A Squared is offline   Reply With Quote
Old 01-29-2012, 08:38 PM   #6
Thanks, I'm all set. Well, I wonder about that missing piece, but otherwise I understand.
Old 01-30-2012, 11:51 AM   #7
Experienced
Jackofall1's Avatar
My guess would be some kind of tubing bender, given the other tools in the kit.
Mark
Favorite Hand Tool Brand jte1130 Tools 33 08-04-2011 11:56 PM
Questions on PEX tubing and clamps DaleB Plumbing 1 02-23-2011 12:47 PM
Tools for Residential Building UpComingBuilder General DIY Discussions 5 12-12-2008 06:49 PM
