What Kind Of Oil For Regular Electrical Motor Gearbox - Tools - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 07:42 PM   #1
Rewards Points: 1,062
Question
what kind of oil for regular electrical motor gearbox
i had to open the gearbox for my 0.5 HP 5 AMP motor that powers my compact concrete mixer and spilled all the old oil. which kind should i use to replace ?
thanks
Old 07-11-2010, 01:02 PM   #2
if its just a gearbox, only .5hp.. id def use a synthetic gear oil, the syn will be thinner so less friction on the half hp, something you can get right at napa or your local car parts store, id prob use something like a lucas 80w synthetic, the higher end synthetics are a few more dollars, but you shouldnt have to replace that barely ever, especially if your using something like this (lucas synthetic, or other higher end gear oils).. or depending on how much you use it, either way you look at it, its a gearbox, use gear oil, you get what you pay for .. do you know how much you need to put in?
sandal82 is offline   Reply With Quote
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Electrical connection question --Over-head electrical works willijimon Electrical 3 03-06-2009 12:01 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
Electrical before drywall? bkeech Drywall & Plaster 10 01-25-2009 05:30 PM
