What Kind Of Detector Is This? - Tools - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 12:44 AM   #1
FordRacer2007's Avatar
Rewards Points: 29
Send a message via Skype™ to FordRacer2007
What kind of detector is this?
Hi, just bought a house and I've been working on it for a few days now and I finally got tired of hearing one of the smoke detectors chirp (at least I thought it was a smoke detector). I reached up and removed the battery and it still chirped, so I unscrewed it and found it was wired into my house, it isn't labeled so here's a pic, I'm hoping someone can give me some information on this as I'm only 22 and new to the home thing.
FordRacer2007 is offline   Reply With Quote
Old 12-12-2010, 12:49 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it looks like it might be a combination CO/smoke deterctor or maybe just a CO detector. It is hardwired with power and maybe interconnected to the other alarms in the house.
There should be a manufacturer and model on the thing somewhere. If you can find it, I'm sure somebody can figure out what it is for sure.
and the chirping; some interconnected units all chirp when one battery goes bad. You might also try just replacing the battery in this unit and see if that corrects it.
Old 12-12-2010, 12:51 AM   #3
Rewards Points: 29
Oh, this is the first time I see that, thanks, I'll try and see if I can find a model number tomorrow.
Old 12-12-2010, 08:16 AM   #4
Rewards Points: 121
So just in case it's not obvious...the battery is for a power failure, so you are still protected if there is an electrical failure. To stop the chirp get a new battery and try it in all of the units, or just change all of them so you don't have to worry.
JoeLena is offline   Reply With Quote
Old 12-12-2010, 09:45 AM   #5
firehawkmph's Avatar
Rewards Points: 1,898
Nap,
You should replace your batteries in any detectors you have that use a 9 volt battery. Pick a date you will remember to do it. Smoke and CO detectors are cheap insurance and do a good job. Your detector is hard wired, which is good, but if the power were to go out they won't work without good batteries in there as a backup.
Mike Hawkins
ret. firefighter
firehawkmph is offline   Reply With Quote
Old 12-12-2010, 10:40 AM   #6
Rewards Points: 29
Thanks to everyone that replied. I will replace that batteries, I never really thought of them being wired and having batteries because I've never really seen the power go out for more than a minute.
Looking for a kind of pest killer spray userid Pest Control 1 05-04-2010 07:06 AM
New kind of weed in lawn? VelvetFoot Landscaping & Lawn Care 9 11-14-2009 10:11 PM
what kind of pipe to use clasact Plumbing 24 10-05-2008 12:48 PM
What kind of breaker TaazKareem Electrical 22 09-26-2008 10:03 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
