What Do I Need To Drill Into Metal Patio Doors For A Lock? - Tools - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 05:40 PM   #1
Rewards Points: 184
What do I need to drill into metal patio doors for a lock?
I am trying to put on a universal lock, like this one:
http://www.doubleasecurity.net/HARDWARE/MAG8755.jpg
And I would need it looks like two holes for the screws, and one hole for the pin. As well as someway to hold the screws into the metal.
TIA
abefroman is offline   Reply With Quote
Old 04-01-2009, 05:51 PM   #2
the Musigician
DangerMouse's Avatar
that's a cool little lock! just a metal drill bit (hi-speed steel carbide) the right size will do fine.
DM
Old 04-01-2009, 05:53 PM   #3
Rewards Points: 184
DM
Will my 12V drill be able to do it?
What is the best way to get screws to hold into metal? I know they will probably go in now, but will become loose over time.
Old 04-01-2009, 06:05 PM   #4
the Musigician
12v is fine. if it's aluminum doors, you could even use a crappy old wood bit! but be careful either way so as not to go too far. use a locking bit stop if you have them or use some tape to mark the bit. the screws SHOULD be self tapping with that unit..... be sure to put it in a spot the drilling won't accidentally hit glass!
DM
Old 04-01-2009, 06:09 PM   #5
the Musigician
as to the screws, i'd use some PL construction adhesive to lock them into place. ( i know guys... i use that gunk for everything)
DM
Old 04-01-2009, 07:40 PM   #6
DM
The most important thing to remember is to stay away from the glass. I was called to install deadbolts on some metal doors on a house, several years ago.While I was there ,the owner of the house wanted to save some money, so he began installing a patio door lock he had purchased himself. While I was working on the front door ,I heard him yell.I looked to see what happened .He had nicked the edge of the glass that was under the metal with the drill bit and the glass in the door started to shatter from the corner until the glass was shattered in the entire door. After seeing that ,I am always extra careful myself, when drilling patio doors.
Handyman Jim Noonan is offline   Reply With Quote
Old 04-01-2009, 08:41 PM   #7
the Musigician
yup, all it would take is a nick on a patio door and it'd be a pile of pieces! lol (tempered glass)
DM
How to drill into metal window header? BrandonDL Carpentry 4 01-29-2009 06:01 AM
painting metal doors pjm Painting 5 06-04-2008 10:55 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
outswing patio doors philS Building & Construction 2 07-11-2007 02:39 AM
Crestline Patio Doors tom_patriot Building & Construction 2 11-24-2006 11:51 PM
