Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-26-2009, 06:47 AM   #1
Weekend Builder
Crackers's Avatar
Question
What is the difference between these two Dewalt?
OK. There are two models of drills / drivers that I am looking at. They are both the same price ($149.00) and seem to be the same.
What is the difference>??????
Dewalt 720 and Dewalt 759.
H.
Crackers is offline   Reply With Quote
Old 06-26-2009, 07:04 AM   #2
It looks like the 759 has a slightly lower speed.
jerryh3 is offline   Reply With Quote
Old 06-26-2009, 01:38 PM   #3
Tool Geek
PaliBob's Avatar
Can you give us a Link to where you found that $150 Price?
Here is the DeWalt DC720KA 18Volt Drill/Driver @ $176.99
http://astore.amazon.com/dewalt-dc72...245919-8419168
And the DeWalt DC759KA 1/2" 18V Drill/Driver @ $157.10
http://dewalt-dc759ka.com/video-reviews.html
Also Check for chuck size and whether One battery or Two
& Stay Safe
.....Bob Lavery
Old 06-26-2009, 07:18 PM   #4
It was a dark and stormy
Yoyizit's Avatar
Sometimes for a lower price you get a better drill because the better one wasn't selling well, for who knows what reason.
The voltage for these drills is the same, so check for how many cents you are paying for each
watt-hour
amp-hour
in-lb of torque
rpm
There may also be a reliability issue, but this is hard to check.
Old 06-26-2009, 07:38 PM   #5
Tool Geek
PaliBob's Avatar
......They are both the same price.....$149
I still could not find that price. That is a very good deal. Both have the same 1.7 Amp-hr Ni-Cad battery. Note on the pic there is distortion which makes the battery on the DC729KA look smaller. It also makes the 720 nose look longer. (the pics were from different sources)
The DC720KA was released in July 2009 which makes it newer than the DC759
http://www.dewalt.com/us/articles/pr...se.asp?ID=1554
Data sheet on the 720:
http://www.dewalt.com/us/products/to...roductID=16338
Data sheet on the 759:
http://www.dewalt.com/us/products/to...productID=8780
For some reason DeWalt describes the 720 as a 'Compact' while there is only a very small difference in size. It might be that the 720 is just the newer model. One source said the 720 had 18 clutch settings while the pics show 17 clutch settings on both drills.
For the two drills at the same price the 720 appears to be a better value.
What is the difference between these two Dewalt?-comparison-dewalt-18v-drills.jpg
& Stay Safe
.....Bob Lavery
Old 06-27-2009, 12:33 AM   #6
The compact wins in my book. Higher power (watts not torque), greater speed range, and lighter weight.
I don't have a clue about reliability. I would assume they are similar, but to get the weight reduction, some parts will have been made of weaker materials. Some purist will have a problem with that, but if the drill doesn't break, it doesn't matter if the gearbox is made of steel or aluminum.
Highlander is offline   Reply With Quote
Old 06-29-2009, 01:23 PM   #7
Weekend Builder
Crackers's Avatar
I hear you.
The 759 is available at COSTCO now, and it comes with two drill bit sets. I just got the 720 from SEARS, it was on special for $149, and the 759 was on special last week (I think this week also) for $159. (CANADIAN DOLLARS)....
Old 07-19-2009, 12:08 AM   #8
I have used both and the 720 is nicer to use. Both have abut the same power. The 720 is newer and a bit lighter and also has a light which is surprisingly handy. the battery life is about the same on both.
joel v. is offline   Reply With Quote
Ridgid 18v vs Dewalt 14.4v xrp vs el cheapo? scottrob Tools 28 05-08-2009 09:45 AM
dewalt 14.4v and 18v drill? revo33 Tools 26 04-18-2009 10:13 AM
Tools for Residential Building UpComingBuilder General Discussion 5 12-12-2008 07:49 PM
Difference between door manufacturers Dcislander Building & Construction 4 02-20-2008 11:17 AM
