Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-11-2011, 10:35 AM   #1
bsa_bob
Question
What did i use--i can't remember the tool????????
I bored a hole in a concrete wall 15 years ago,and i made a perfect round 1
" hole.Not any burrs, smooth inside -busted out the other side, but no matter.I have looked everywhere in my tools and can't --now come up with the suitable i used before. Can you point me in the right dircetion on this, the hole is for 1" copper water line.thanks for what you may have bob s
bsa_bob is offline   Reply With Quote
Old 07-11-2011, 12:19 PM   #2
DIY Hack
Mr Chips's Avatar
because it busted out the other side, I'm guessing you used a hammer drill. If it was really smooth probably a Quad tipped bit ( a concrete bit with 4 carbide cutters instead of the usual 2)
Or you can use a dry core bit if you want it SUPER smooth
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
BigJim (07-11-2011)
Old 07-11-2011, 12:52 PM   #3
bsa_bob
Does this[ bottom core bit come in sizes to fit the standard, 1/2" drill motor, and where do i find this one?At a hardware maybe? It could have also been the prior 4-cutter type.....but---- yes it was probably not drilled by me .But rather, the new furnace guys, that installed a cable thru this particular hole.No wonder i can't find these in my tool chest, theres everything else in there BUT! these
Thank you Mr Chips!! please let me know,
Old 07-11-2011, 01:23 PM   #4
DIY Hack
Mr Chips's Avatar
for the size you need you should be able to find something that will fit in a standard 1/2 chuck, but for anything bigger you'll probably need an SDS, max, or spline. These core bits can be a bit pricey though, so you might want to call around and see if you can rent one if you only have a couple holes
Old 07-11-2011, 02:02 PM   #5
bsa_bob
OK!!thank you. "good bye Mr Chips". bet you haven't heard that one to many times. aayy, bob s
Old 07-12-2011, 04:28 AM   #6
In addition to rent a core bit, you can buy an economical one, and pay attention if it is sharp enough.
radish is offline   Reply With Quote
Old 07-12-2011, 05:32 AM   #7
Experienced
Jackofall1's Avatar
There is always the old star drill, tapped with a hammer and rotated between strikes, works very well and are inexpensive.
Mark
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 08:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 07:02 PM
