-   Tools (http://www.diychatroom.com/f29/)
-   -   What did i use--i can't remember the tool???????? (http://www.diychatroom.com/f29/what-did-i-use-i-cant-remember-tool-110361/)
bsa_bob 07-11-2011 09:35 AM
I bored a hole in a concrete wall 15 years ago,and i made a perfect round 1
" hole.Not any burrs, smooth inside -busted out the other side, but no matter.I have looked everywhere in my tools and can't --now come up with the suitable i used before. Can you point me in the right dircetion on this, the hole is for 1" copper water line.thanks for what you may have bob s:(
Mr Chips 07-11-2011 11:19 AM
because it busted out the other side, I'm guessing you used a hammer drill. If it was really smooth probably a Quad tipped bit ( a concrete bit with 4 carbide cutters instead of the usual 2)
http://www.bamanufacturing.com/image...0pic%20004.JPG
Or you can use a dry core bit if you want it SUPER smooth
http://c.shld.net/rpx/i/s/pi/mp/8901...ed475d8b60f985
bsa_bob 07-11-2011 11:52 AM
Does this[ bottom core bit come in sizes to fit the standard, 1/2" drill motor, and where do i find this one?At a hardware maybe? It could have also been the prior 4-cutter type.....but---- yes it was probably not drilled by me .But rather, the new furnace guys, that installed a cable thru this particular hole.No wonder i can't find these in my tool chest, theres everything else in there BUT! these
Thank you Mr Chips!! please let me know,
Mr Chips 07-11-2011 12:23 PM
for the size you need you should be able to find something that will fit in a standard 1/2 chuck, but for anything bigger you'll probably need an SDS, max, or spline. These core bits can be a bit pricey though, so you might want to call around and see if you can rent one if you only have a couple holes
bsa_bob 07-11-2011 01:02 PM
OK!!thank you. "good bye Mr Chips". bet you haven't heard that one to many times. aayy:rolleyes::), bob s
radish 07-12-2011 03:28 AM
In addition to rent a core bit, you can buy an economical one, and pay attention if it is sharp enough.
Jackofall1 07-12-2011 04:32 AM
There is always the old star drill, tapped with a hammer and rotated between strikes, works very well and are inexpensive.
Mark
