Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-15-2009, 06:28 PM   #1
What is the best power rod for clogged drains?
I tried a manual one, can it gets stuck, I think on a lip or something, when I have the plumbers out with their rodding machine, that goes through no problem, it seems that one, swings the cable around to it gets over the lip.
I also tried on you attach to a drill and that was worthless.
Is it worth it do spend $400 for one of the rodding machines?
Is there any technique to using one? I am just worried about forking over the $400 and the have the cable get stuck on the lip again.
abefroman is offline   Reply With Quote
Old 02-16-2009, 02:24 PM   #2
The best drain cleaning machine is probably a "jetter". Basically, a jetter is a high pressure washer with a long hose you push into your drain pipe. You connect the jetter to a water supply and the electric pump pumps that water down the jetter's hose. The water comes out the nozzle at the end of the hose at anywhere from 800 to 2100 psi, and cleans the ID of your drain pipe clean as a whistle.
Because of the way the jetter works, you can use the same jetter to clear anything from a 1 1/4 inch drain to a 6 inch drain pipe. The jetter hose is much thinner and more flexible than a metal snake, so it's easier to get into and out of drains. The jetter hose doesn't rust like a steel snake, so there's virtually no chance of having it break or get stuck in the drain pipe.
But, even an inexpensive jetter is gonna cost more than $400, I think.
http://www.ridgid.com/Tools/KJ1350-Water-Jetter
Maybe have a video inspection of your drain piping done to see what's actually causing the clog. You may have a cracked drain pipe, in which case clearing it is only a temporary fix.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 12 04-25-2011 03:11 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
