Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-22-2012, 11:01 AM   #1
What is This?
Cleaning out some tools my Dad gave me, and I ran across this.
Looks like a wrench handle, with a length of chain. An "O-Ring" is at the end of the chain. Where the chain attaches to the handle, there is a little crescent shaped piece of metal, with teeth in it.
Attached pic. thanks!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 04-22-2012, 11:05 AM   #2
What is This?
chain strap wrench. PLumbers/electricians use it for wrenching large pipes or up close work.
Jeeps is offline   Reply With Quote
Old 04-22-2012, 11:07 AM   #3
What is This?
Originally Posted by Jeeps
chain strap wrench. PLumbers/electricians use it for wrenching large pipes or close proximty work.
I have one just like that.
The only negative I find is that it'll crush pipes if you really put some a*s behind it!
Doorman54 is offline   Reply With Quote
Old 04-22-2012, 11:10 AM   #4
DIY Enthusiast
sublime2's Avatar
What is This?
I'm going to guess its a tool to cut large lead pipe.
Close....... except for the cutting part....lol
sublime2 is offline   Reply With Quote
Old 04-22-2012, 11:31 AM   #5
What is This?
http://www.reedmfgco.com/index.html?...chain_wrenches
Old 04-22-2012, 12:12 PM   #6
What is This?
I think you are thinking of soil pipe cutters that break/cut cast iron pipe. Big ole' nasty looking tool.
Old 04-22-2012, 10:25 PM   #7
Missouri Bound's Avatar
What is This?
I've actually used one to remove the glass "mason jar" globe from explosion proof lights when some racked it down too tight.
Do you want it your way or the right way?
Old 04-24-2012, 03:36 AM   #8
Tool Geek
PaliBob's Avatar
What is This?
Originally Posted by Missouri Bound View Post
I've actually used one to remove the glass "mason jar" globe from explosion proof lights......
Too bad you didn't have one of these. The same Rigid series has one with a 48" strap
For light duty DIY here is a set of Rubber Strap Wrenches:
http://www.harborfreight.com/2-piece...set-94119.html
& Stay Safe
.....Bob Lavery
Old 04-24-2012, 04:12 AM   #9
Tool Geek
PaliBob's Avatar
What is This?
Yep that's it
& Stay Safe
.....Bob Lavery
Old 04-24-2012, 09:38 AM   #10
What is This?
Have one, but it kept slipping. I wrapped the jar in masking tape first to protect me if it broke. The strap kept slipping but the chain "dug in" a bit so it worked.
