Weedeater Head Stuck - Tools - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 08:02 PM   #1
Weedeater head stuck
The knob on my weed eater is stuck it won't unscrew what could be wrong, HELP
DMCM81 is offline   Reply With Quote
Old 06-17-2013, 08:52 PM   #2
Are you sure it screws off? Mine just pulls off.....the part that you wind the string around that is...
Squints is offline   Reply With Quote
Old 06-17-2013, 09:03 PM   #3
Yep I'm screwing it off but it won't unscrew it's stuck I don't want to try to unscrew with the pillars I don't want it to break
Old 06-17-2013, 09:13 PM   #4
Rewards Points: 6,652
They unscrew the opposite direction the head turns.
Old 06-17-2013, 10:43 PM   #5
Rewards Points: 14,312
May be left hand threads.
Never seen one that screws off unless your replacing the whole head and not just replacing the string.
Old 06-18-2013, 06:26 AM   #6
PoleCat's Avatar
Rewards Points: 1,652
There is a bolt in the cap in a channel. If the cap is turning but not getting loose then it is likely the bolt has chewed the channel smooth. If it is that type you will have to replace the cap after you destroy it to get at the bolt.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-18-2013, 06:54 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
+1 to it being reverse threaded.
Old 06-18-2013, 07:10 AM   #8
Rewards Points: 3,130
My weedeater has a cap that unscrews. It is reverse threaded.
Old 06-18-2013, 07:47 AM   #9
PoleCat's Avatar
Straight shaft vs curved shaft they are opposite rotation. Funny, after around 50 years of being invented there is yet to be a great spool head design.
The Following User Says Thank You to PoleCat For This Useful Post:
gregzoll (06-18-2013)
Old 05-08-2017, 03:32 PM   #10
Rewards Points: 2
Re: Weedeater head stuck
Did you figure this one out? I am having same issue with what looks like the exact same head.
RetroVertigo is offline   Reply With Quote
Old 05-08-2017, 03:36 PM   #11
ZTMAN's Avatar
Rewards Points: 522
Look for an owners manual on line Retro. You probably have a reverse thread as well
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 05-08-2017, 03:39 PM   #12
Rewards Points: 1,491
Mine has two little holes that you have to line up and then you can stick a nail in there to lock the shaft in place. Then the head unscrews to the RIGHT.
Checking the manual is probably a good idea too.
mathmonger is online now   Reply With Quote
Old 05-08-2017, 04:05 PM   #13
Mike Milam's Avatar
Rewards Points: 304
I had one like that before I went cordless last year. Mine was right hand thread. It stuck from time to time as well. I grabbed a pair of channel locks and broke it loose. Not much danger in breaking the knob.
WOW! Just realized this was from 2013, my bad.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Shower head dilemma segal Plumbing 2 01-23-2013 11:34 PM
Suggestions for 2 head shower control bodine465 Plumbing 10 11-18-2012 08:53 PM
typical head pressure? gone rayson HVAC 7 10-05-2012 06:41 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 08:13 AM
outside faucet sprays at head attachment Synthia212 Plumbing 11 03-13-2009 05:53 AM
