-   Tools (http://www.diychatroom.com/f29/)
-   -   Weed Wacker (http://www.diychatroom.com/f29/weed-wacker-10018/)
cibula11 07-20-2007 09:57 AM
Weed Wacker
I am needing a weed wacker, and I am considering a battery powered model. Anyone heard anything or can give helpful advice about them?
slakker 07-20-2007 02:18 PM
I have a B&D 18v weed whacker... but like other tools, it does what it's designed. Basically it's good for a small yard and with at least 2 batteries charged...
I've sinced went to a Stihl power head with whacker attachment and like the power and no need to swap batteries. But it is noisier and heavier (and less "green")...
jridder 05-26-2009 10:05 PM
I bought an electric years ago and it had little power, so I ended up buying a gas model. It depends on how big your yard is I suppose. I bought my gas powered through this site and I think that they have battery powered too. http://www.weedwackerstore.com
mark! 06-06-2009 05:18 AM
I was using an electric weed eater for a while when I moved in with who is now my wife, it's all she had. I soon purchased a Troy Bilt 4-cycle weed eater for a large sized yard, love it.
DangerMouse 06-06-2009 05:37 AM
i have an echo (gas) with a small circular saw blade retrofitted to it, and a B&D rechargeable bought 8 years ago that still charges and works fine with a reversed dado blade 'claw' sharpened on the outside edge. both work fine, though i use the B&D more. the echo flies through tall grasses and small saplings easily. the B&D is nice for cleanups in tight areas. of course, i do not recommend everyone retrofitting saw blades to your tools, but i got tired of broken plastic all over and replacing 'string' constantly.
DM
Kap 06-06-2009 01:54 PM
Echo, Stihl and others have blades specifically designed for their machines. Different types for different purposes. Some will take out thick brush, some will cut trees up to six inch diameter.
I do a lot of clearing/brush cutting work. Some of those blades can go through a leg like a hot knife through butter.
I would recommend the purpose built blades over a retrofit, as the purpose built are designed for minimal kickback.
cashishift 06-07-2009 10:53 PM
I cant say I would recommend using a trimmer to cut a six inch diameter tree.. that's chainsaw territory!!!
If you plan on clearing brush and small trees (i wouldn't go anything bigger than 1" myself) spend the extra money for a trimmer designed to clear brush such as this unit from Stihl:
http://www.stihlusa.com/trimmers/FS350.html
Kap 06-08-2009 12:28 AM
I agree there. I wouldn't put a blade on the average weed whacker unless it was just for thick grasses.
Smaller jobs I use:
http://www.shindaiwa.com/usa/en/prod...410x_c3410.php
And for the big jobs:
http://www.husqvarna.com/us/forest/p...roducts/355fx/
