Weed Eater Repairs - Carburator - Tools - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 09:17 AM   #1
Weed eater repairs - carburator
I have a Weed Eater TE475Y string trimmer and the choke selector is broken off. Without it I can't start the trimmer and its pretty much a big paperweight. I did some google searching and according to ereplacementparts.com I can order a new carburetor, however I have never done any engine work of any kind. Is replacing the carburetor a straight forward process or should I take it to a shop for repairs? The manual also lists two different models for the carb - how do I know which is correct, or would they both work interchangeably?
After it's all said and done I would be over what I paid for it (second-hand from a co-worker, sold as-is.) Is it even worth trying to fix or should I just buy a new trimmer?
cellophane is offline   Reply With Quote
Old 05-27-2010, 12:05 PM   #2
By my experience, replacing a carb is pretty easy. The hardest part often is gaining access, with all the covers and shrouds. Carb replacement is often two screws, a fuel line, and a throttle cable.
oberkc is offline   Reply With Quote
Old 05-27-2010, 12:44 PM   #3
Rewards Points: 249
Can you post a picture of the choke selector and where it broke off? Maybe you can make a replacement, or JB weld the original back together? Why can't you just buy the choke lever for the 6 bucks it lists on the replacement parts list?
Durt Ferguson is offline   Reply With Quote
Old 05-27-2010, 01:44 PM   #4
The choke lever replacement depends on the carburetor model. The Walbro carb is not repairable, the Zama carb is. I did stop by the local hardware store and talked to the guy there that works on small engines and he was able to get me sorted out (I hope.)
Luckily I do have a Zama carb and can buy the new part and be on my merry way, assuming I don't screw up the installation too much. His advice was if I had to replace the carb it might be time to start looking around for a new trimmer. The tech did show me how to replace the part that is broken - so I'll order one and give it a go.
Pictures enclosed. In the picture without the shroud - the yellow piece is broken as well, I am ordering that also.
Weed eater repairs - carburator-2010-05-27-14.42.53-large-.jpg   Weed eater repairs - carburator-2010-05-27-14.43.15-large-.jpg
Old 06-01-2010, 06:41 PM   #5
Rewards Points: 252
Sounds like you're on the road to resolving your repair. Congrats!
I just wanted to quickly share my experience: My string trimmer (a HomeLite) recently had carburator problems, and I wanted to try fixing it myself (even though small-engine repair is NO specialy of mine). I found a great video on YouTube where an expert breaks down a carb step by step, cleans it and re-builds it. It was so simple and straight-forward that I tried it on mine. Worked like a charm! Using his tuning techniques, I even have it running better than it did years ago.
If interested, here's a link to the video:
Good luck.
Itsdanf is offline   Reply With Quote
Old 06-23-2010, 03:40 PM   #6
I've replaced all the parts, but the choke lever seems loose and it doesnt 'lock' into the various choke positions, making starting and running rather difficult. I'm pretty sure I'm just missing something simple but I have no clue how to adjust it.. Anyone have a suggestion?
Old 09-28-2011, 06:15 PM   #7
dembones
Hello I,m a newby, I was wondering where you found the chock lever and shaft for a zama carburator, I also need both for a C1U model for a weedeater trimmer, Can you help.
dembones is offline   Reply With Quote
Old 10-19-2011, 06:24 PM   #8
choke lever
Durt Fergoson, the lever broke off just shy of the carb it self and my 18 yr old does not know what he did did with the lever. My guess is he got med and threw it as far as he could. Any way when I removed the choke plate to removed the shaft, it didn' t dawn on me to watch for the spring and super small ball bearing for the detents in the positions of the choke. Since the weedeater is about 10 years old, I'll revert back to an electrical one I have or get a new one. Thank you
Old 10-19-2011, 06:28 PM   #9
Cellophane You probably lost a super small spring and a type of ball bearing that went into the carb as you put the choke lever back in. I did the same thing taking a broken choke shaft out of mine
Weed Eater carburetor help rocko918 Landscaping & Lawn Care 13 04-29-2010 05:49 AM
Weed eater will not start? Jake3333 Landscaping & Lawn Care 5 01-15-2010 11:50 AM
ryobi weed eater lilsara88 Landscaping & Lawn Care 2 05-13-2009 08:31 PM
weed eater repairs MDduck865 Landscaping & Lawn Care 1 04-05-2009 08:15 PM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 11:12 AM
