Weatherstripping Old Windows - Router Question - Tools - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 01:40 PM   #1
Rewards Points: 526
Weatherstripping old windows - router question
I have been looking into ways to weatherstrip my old double hung windows as part of the process of restoration. I want to go with a barbed style that requires a slot. As they have not been weatherstripped before I have to make the slot. The stripping manufacturers recommends a slot gap of 5/64th of an inch to accommodate the barb. This size of blade is available as slot cutter router bit.
I am not an experienced router user and actually will be buying my first one for this project. I have been looking at the PC 690LR as it seems affordable and reliable and I will make use of it in the future on other projects I have in mind. At the same time, this window project is less about power and more about precision, so maybe the Bosch Palm router is the better choice. Any opinions on this or general advice for doing slot cutter routing? Thanks.
Windows is offline   Reply With Quote
Old 10-29-2010, 03:58 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I have not used my Bosch Colt with a Slot Cutter but it would be easier to handle with one hand than the PC 690
Along with the router you will most likely need an edge guide to zero in on the cutter depth, so the Colt has the edge Guide included in the Bosh Colt Model PR20EVSK ($99.99) @ Amazon.
What type of window counterbalance do you have?
If you have the old rope & lead weights system there are newer style Spring Balances that are easy to install (Tommy thinks so).
If your windows are separated with a wood parting bead that have been painted I have found my best solution is to replace them with new unpainted wood bead. I replace the parting bead whenever I replace an Acme Twin Sash Balance.
Some more Tips
Disclaimer
& Stay Safe
.....Bob Lavery
The Following 2 Users Say Thank You to PaliBob For This Useful Post:
Tom Struble (10-29-2010), Windows (10-30-2010)
Old 10-29-2010, 06:55 PM   #3
DIY staff
Rewards Points: 7,174
Just a couple of thoughts on choosing a router----
The Porter Cable that you are looking at is a fine choice---tough as nails,easy to adjust and well balanced---I have several of them.
The smaller trim routers are actually harder to controle than the full sized routers--
The smaller base makes it more likely to tip and give you a wavy edge----
They do have thier uses,however for your first router I suggest a full size,fixed base unit like the Porter Cable.--Mike--
Old 10-30-2010, 05:20 PM   #4
Rewards Points: 526
Thanks guys for the input. I think I will go with the 690. Bob, I am almost finished repairing my windows and I wish I could have spoken to you a few months ago. I have been replacing all of the parting beads, partially because the upper sash has a weird flange that necessitates breaking the parting bead before the sash can be released, but the new bead has been giving me some trouble. I eventually figured out a way to paint/stain them and reinstall them without too creating too much friction with the sashes, but I wish it had occurred to me to install them unpainted. That seems like an elegant solution - simple too. The windows are counter balanced with the pocket weights and that whole system is in good shape. I switched them all over to sash chain and it seems that was a good decision. Thanks again.
The Following User Says Thank You to Windows For This Useful Post:
oh'mike (10-30-2010)
Old 10-30-2010, 08:22 PM   #5
Tool Geek
PaliBob's Avatar
Windows, The PC 690 was second router I bought and I still have it. There are probably more 690's around than any other single model.
You also may need an Edge Guide
Another useful router accessory (when you get into using a hinge template to mount hinges) is a Template Guide. Here is a whole Set
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
Windows (10-31-2010)
Router Advice diyheroe Carpentry 0 09-24-2010 09:09 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
