Water In Jigsaw - Tools - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 10:08 PM   #1
Rewards Points: 107
water in jigsaw
I had to use my jigsaw today on the bottom of my deck and it got very muddy. I rinsed it off with my hose. It appears to be working, but I am curious if I have caused any significant damage to it.
Ranger1227 is offline   Reply With Quote
Old 06-24-2011, 10:14 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
THAT was a good idea!
I would blow it out with compressed air and let it sit in the sun for a day or two. I'll bet it will be fine. Don't be tempted to trigger it beforehand just to see if it works.
XXX
Old 06-24-2011, 10:15 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
probably didnt help it any. i dropped a drill in a pool a few years back and it still works.
mustangmike3789 is offline   Reply With Quote
Old 06-24-2011, 10:23 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I doub't there is any real damage. As long as you don't try to run those things when they are wet they generally survive a dip now and then.
XXX
Old 06-25-2011, 07:16 AM   #5
DIY staff
Rewards Points: 7,174
Spraying a wet electric tool with WD-40 and getting it to dry in the sun works wonders.
A freak rainstorm dumped 14"s of water on a basement job some years back---The contractors entire tool collection sat under 3' of water for hours.
Compressed air and WD-40----a lot of sunshine---all tools survived!
Old 06-25-2011, 08:07 AM   #6
the Musigician
DangerMouse's Avatar
I think I'd do it the other way around. WD-40 to displace all the water, then compressed air to remove any remaining water OR WD-40.
I've seen WD-40 and CR-556 kill power tools before, so I'd be real cautious there.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
oh'mike (06-25-2011)
Old 06-25-2011, 09:00 AM   #7
A Little Of Everything
Rewards Points: 1,364
So YOU'RE the guy in that picture!
DrHicks is offline   Reply With Quote
Old 06-25-2011, 09:48 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
What's the problem? He's got his PPE on
Kyle
Old 06-25-2011, 06:13 PM   #9
Rewards Points: 107
Thanks, guys, I actually used it again yesterday afater cleaning it, and it still works. I don't use a jigsaw very often, so it will have plenty of time to dry
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
