Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-20-2009, 12:08 PM   #1
very clogged dryer vent. Not just lint
Hello
I have an embarrassing question. I feel like one of those husbands on a situation comedy where I should have just called someone in the first place.
So with that said.
I have a clogged dryer vent. Using a dryer vent cleaning kit (long flex rods that you screw together and snake the vent) I was able to remove a lot of lint.
As I continued it’s now obvious I did not tighten one of the rods sufficiently. So now I have lint, flexible rod and brush head stuck in the vent (hence the comedy).
I have tried several ways to free this up (Short of moving the dryer and plowing air thru the vent).
Since the flex rod has metal I attached a strong magnet to an electrician’s wire snake hoping to snag it and pull it out. But no joy.
What I would love to find is a flexible snake that has a handle allowing me to GRAB and hold onto the rod and pull out.
Is there such a tool? Or are there others was to clear the vent?
thanks
catman is offline   Reply With Quote
Old 04-20-2009, 12:29 PM   #2
the Musigician
DangerMouse's Avatar
can you see the rod?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-20-2009, 12:51 PM   #3
no cannot see it. The vent turns about 24 inches in and that is where it is stuck
Old 04-20-2009, 03:00 PM   #4
Middle Aged Man
JFXG's Avatar
Send a message via AIM to JFXG
I'm assuming the duct run is not accessible externally. Correct?
JFXG is offline   Reply With Quote
Old 04-20-2009, 05:48 PM   #5
Catman, try to get a measuring tape in and see how far in you need to reach. Post dimensions if you can as per pipe depth and diameter. If I understand your threaded extension has disconnected around a bend, 24" or so within the wall.
Where is the bend, wall ceiling, main floor between joists, etc.
Chemist1961 is offline   Reply With Quote
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
moisture in dryer vent and door monkeygirl Electrical 13 01-10-2009 10:11 AM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 09:44 AM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
