Vacuum Adapter For Dewalt D26441 - Tools - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 08:15 PM   #1
Rewards Points: 154
Vacuum Adapter for Dewalt D26441
Hey All,
Just bought a rigid shop vac today.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
The hose is too big for my Dewalt D26441 sander vacuum adapter. Does anyone know if I can purchase an adapter for this connection? Checked on google and didn't find any. I'm thinking that I have to make a custom hose adapter. Any guidance on what products to use will be greatly appreciated.
Thanks.
llckll is offline   Reply With Quote
Old 02-12-2010, 08:56 PM   #2
firehawkmph's Avatar
Rewards Points: 1,824
IIlck
Check this link to porter cables site. They have some adapters available, not sure exactly what you need.
http://www.deltaportercable.com/Prod...4340.4364.2483
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-12-2010, 08:59 PM   #3
Rewards Points: 154
Sweet, I'll check it out.
Old 02-12-2010, 09:03 PM   #4
Too Short? Cut it Again!
I've found I can usually making something work for sanders and things with PVC plumbing fittings. I just slip fit the PVC components; I don't glue them so I can change things. I adapted the exhausts on all my sanders to work with the shop vac this way. I have one set-up with about 10-12 feet of flex tubing that hooks to the sander I use for surfacing wall repairs (secure it with duct tape so it does not slip off). It goes to a reducer sleeve that it fits into perfectly. That sleeve fits in a PVC fitting that fits the hose on the shop vac perfectly (although I secure the two together with duct tape also).
Anyhow, the PVC fittings are dirt cheap and if you play around you can find either an ID or OD "something" that will fit just about any size tubing and work well. May not look as elegant as a custom adapter but will not set you back $10-15 either.
Old 02-12-2010, 09:14 PM   #5
Rewards Points: 154
Originally Posted by sdsester View Post
I've found I can usually making something work for sanders and things with PVC fittings, reducers and things. I adapted the exhausts on all my sanders to work with the shop vac this way. I have one set-up with about 10-12 feet of flex tubing that hooks to the sander I use for surfacing wall repairs (secure it with duct tape). It goes to a reducer sleeve that it fits into perfectly. That sleeve fits in a PVC fitting that fits the hose on the shop vac perfectly. I don't glue the PVC together.
ID or OD? Don't know what those are. I will check out Lowes and see if I can make a custom solution since I have a gift card.
Thanks.
Old 02-12-2010, 09:21 PM   #6
Thanks.
Sorry, I was referring to either inside diameter or outside diameter of the fittings to adapt to hoses or tubing. I have some where the hose fits better over the fitting and some where they fit better inside of it. You just have to play around a bit.
Making a battery powered device work with an AC/DC adapter? FlyGuy Electrical 14 11-21-2010 08:28 PM
Trap Adapter Leak? kcrossley2 Plumbing 6 01-27-2010 01:55 AM
Repairing an Apple adapter (A1184) ... Phantombox Electrical 4 12-15-2009 09:44 AM
Pitless Adapter Submersible Pump Wild Blue Plumbing 5 08-31-2009 02:02 PM
Removing 2" marble toilet flange adapter for handicapped proofer Plumbing 20 04-21-2008 05:31 PM
