Using A Paint Gun - Tools - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 11:41 AM   #1
Using a paint gun
I Just purchased a Husky gravity feed spray gun (HDS580). There is no instructions on how to thin the paint either in the manual or on the Glidden paint can. I got a high gloss white, water based paint in a 1 Quart can. And I'm painting an entertainment center that I made using cabinet grade lumber.
Clark
clark77494 is offline   Reply With Quote
Old 08-14-2011, 12:04 PM   #2
Experienced
Jackofall1's Avatar
Welcome clark77494, to the best darn DIY'r site on the web.
I believe to thin a water based paint for spraying you would use a product called Floetrol and thinning instructions will be included with that product.
Make sure you are primed, etch sanded and tacked prior to spraying out the finish, personally I would go with an oil based product for better results.
I have never used it (Floetrol), just picked this info up reading through many posts.
I am sure there will be others which may add more insight.
Mark
Old 08-14-2011, 12:27 PM   #3
I just looked up Floetrol on the Home Depot website. It looks like it will do the trick. Thank you for your help.
Clark
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
