-   Tools (http://www.diychatroom.com/f29/)
-   -   Using a paint gun (http://www.diychatroom.com/f29/using-paint-gun-113993/)
clark77494 08-14-2011 11:41 AM
Using a paint gun
I Just purchased a Husky gravity feed spray gun (HDS580). There is no instructions on how to thin the paint either in the manual or on the Glidden paint can. I got a high gloss white, water based paint in a 1 Quart can. And I'm painting an entertainment center that I made using cabinet grade lumber.
Clark
Jackofall1 08-14-2011 12:04 PM
Welcome clark77494, to the best darn DIY'r site on the web.
I believe to thin a water based paint for spraying you would use a product called Floetrol and thinning instructions will be included with that product.
Make sure you are primed, etch sanded and tacked prior to spraying out the finish, personally I would go with an oil based product for better results.
I have never used it (Floetrol), just picked this info up reading through many posts.
I am sure there will be others which may add more insight.
Mark
clark77494 08-14-2011 12:27 PM
I just looked up Floetrol on the Home Depot website. It looks like it will do the trick. Thank you for your help.
Clark
