Using Miter Saw On Steel - Tools - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 10:28 AM   #1
using miter saw on steel
Is it OK to use a standard carpentry miter saw on steel? Want to use my 10" delta to cut angle iron, tubing, etc. My concern is about high RPM's destroying the blade.
beerdog is offline   Reply With Quote
Old 02-20-2011, 01:16 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Another concern would be metal dust getting in the motor and eating the armature and brushes up. Also be aware that the metal dust will get in the crevices and you will not be able to turn the angle as it will surely gald and lock.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-20-2011, 02:20 PM   #3
DIY staff
Rewards Points: 7,174
If you are going to cut steel,You will need a steel cutting blade---They are a steel disk with no teeth.
The abrasive cut off wheels should not be used--they will be to worn to complete the cut--
If you like your saw --don't cut steel with it--It will never be the same---Borrow or rent a porta-band--(hand held electric bandsaw)
Old 02-20-2011, 03:49 PM   #4
Remodeler
Rewards Points: 320
I wouldn't. Too many rpm, not enough horsepower, and probably doen't have a material clamping method. They simply are not designed to handle steel.
I have a Milwaukee dry cut metal saw and it works very well, kinda pricey but a lot more power and half the blade speed of a miter saw. It will make nice clean cuts and has a very good clamping vise. It uses a blade with carbide teeth, it looks very similar to a wood cutting blade but is designed for metal.
If you don't need quite as good of a cut a decent abrasive chop saw can be had for less than half the price. They cut fine, the blade wears reducing capacity and it throws sparks and dust. The metal will get hot during the cut too. It will work fine for most jobs, sure beats a hacksaw. If you don't try to force the cut the blade will last much longer. Used one for a long time before the upgrade. The biggest downfall is you can't cut just a little more off, where the dry cut saw will easily cut off a blade width or a sliver as thin as a dime.
iamrfixit is offline   Reply With Quote
Old 02-20-2011, 10:41 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by beerdog View Post
Is it OK to use a standard carpentry miter saw on steel? .......
No, use a Metal Cut Off Saw
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-21-2011, 07:32 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I'm with Bob and the others, nuttin good will come out of trying this. Don't do it
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
miter bar problem ChrisMohrSr Carpentry 2 02-06-2011 08:47 PM
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 01:50 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
