#1 |
Use drill as screwdriver
Hi there,
I have an older model Bosch drill without a torque converter, but would like to drive in some screws. Is there an attachment out there that would allow me to do this (I'm assuming you should have a torque converter to drive in screws)? Thanks! |
#2 |
Electrical Contractor
Not really.
What size screws are you talking about? Once you drive a few, you get the feel for it.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Household Handyman
What type head on the screws? Phillips, slotted, torx, Robison, etc.? IF slotted, forget it, you'll be chasing the screw driver bit all over. Using the proper driver bit, you will find that you will learn how it do this, and quick.
#4 |
the drill does have variable speed?
#5 |
Try it ... start off slow ... should be fine, if not, you will know pretty quickely
#6 | |
A Little Of Everything
Use drill as screwdriverQuote:
If it's a simple On/Off trigger, you're going to have a hard time making it work. |
#7 |
I have a variable speed drill I use regularly as a power screw driver. As others here have already said, once you get the feel of it it works like a charm.
#8 |
the Musigician
Please use the red ! to report spammers, do not quote them, as it makes our job twice as hard.
Thank You! DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#9 |
Sorry. Got PO'd and reacted without thinking.
#10 |
the Musigician
S'ok.... we all hate spammers here.
DM
| Display Modes | |
| Broken caliper bolt | chrissyb | Automotive Repairs | 12 | 12-28-2009 04:18 PM |
| Rookie needs advice - How to remove old thinset from concrete floor? | rookie floor layer | Flooring | 9 | 10-04-2009 01:01 PM |
| Bosch GSB 16 RE drill | Coxy | Tools | 0 | 05-28-2009 02:46 AM |
| recommendations for an all-purpose drill | mcvane | Tools | 18 | 11-29-2007 10:12 AM |
