Use drill as screwdriver
Hi there,
I have an older model Bosch drill without a torque converter, but would like to drive in some screws. Is there an attachment out there that would allow me to do this (I'm assuming you should have a torque converter to drive in screws)? Thanks! |
Not really.
What size screws are you talking about? Once you drive a few, you get the feel for it. |
What type head on the screws? Phillips, slotted, torx, Robison, etc.? IF slotted, forget it, you'll be chasing the screw driver bit all over. Using the proper driver bit, you will find that you will learn how it do this, and quick.
the drill does have variable speed?
Driving screws with drill
Try it ... start off slow ... should be fine, if not, you will know pretty quickely :)
If it's a simple On/Off trigger, you're going to have a hard time making it work. |
I have a variable speed drill I use regularly as a power screw driver. As others here have already said, once you get the feel of it it works like a charm.
Please use the red ! to report spammers, do not quote them, as it makes our job twice as hard.
Thank You! DM |
Re Spammers
Sorry. Got PO'd and reacted without thinking.
S'ok.... we all hate spammers here.
DM |
| All times are GMT -4. The time now is 08:33 PM. |
