Unused Air Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 12-08-2013, 05:42 PM   #1
Rewards Points: 135
Unused air compressor
I bought a Sears Craftsman 25 gallon air compressor 2 1/2 years ago that is in the unopened box, never used. I do not have plans in the near future of using it. Is it bad to let sit unused like letting a car sit without starting it and running periodically?
elmaur is offline   Reply With Quote
Old 12-08-2013, 06:04 PM   #2
Rewards Points: 13,960
Oil less?
Is it stored in a dry area?
Old 12-08-2013, 06:08 PM   #3
DIY staff
Rewards Points: 7,174
I think you will be fine--however, before putting it in service, spin the compressor by hand to redistribute the oil--and change the oil.
That's a big boy--25 Gallon tank.
Old 12-08-2013, 06:11 PM   #4
Rewards Points: 135
From Sears description:
"Aluminum single-stage oil lube pump with cast iron cylinders give quality performance"
It sits in the garage, a dry area but not heated although this is Tucson AZ so no long cold winter but summer is hot.
Old 12-08-2013, 06:14 PM   #5
Rewards Points: 135
This one:
http://www.sears.com/craftsman-profe...&blockType=G17
Old 12-08-2013, 06:33 PM   #6
DIY staff
If it has never been run,you should be safe from the moisture damage that can cause tanks to rust---
I just retired one rather like that----I bought it in 1980---left it plugged in and under pressure for almost 15 years----I stand by what I said---you will be fine--that's a tough unit.
Old 12-08-2013, 06:34 PM   #7
In a little over my head
Rewards Points: 706
I'm sure that if it was sitting in a Sears warehouse somewhere, they'd sell it without a thought. Check the oil before you run it. Run it for an hour or so. Change the oil.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
oh'mike (12-08-2013)
Old 12-08-2013, 10:04 PM   #8
Rewards Points: 135
Thanks all.
Old 12-08-2013, 10:23 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Or you could do a noble thing and donate said compressor to some deserving DIY'r.....
Call it a secret Santa gift....
In all seriousness....maybe donate it to a school or church.
Old 12-08-2013, 10:34 PM   #10
Rewards Points: 135
I think I'll let it sit where it is for now. My original plans for using it were derailed by financial and relationship issues which hopefully are getting worked out.
Old 12-09-2013, 08:08 AM   #11
Rewards Points: 5,974
To leave it sit I would open the petcock on the bottom of the tank. That way if there is any condensation it will drain out. I mean leave it open while in storage.
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
