Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-19-2010, 09:37 PM   #1
Wire Chewer
Red Squirrel's Avatar
typical rental costs for hole saw
I need to punch a 4 inch hole in cinder block and brick. Debating on renting or just buying the bit for it. How much typically would it cost to rent the tool that can do this job? Is it somewhere like $30 or is it much higher? I can buy a bit for my drill for under $100 so if renting costs near that, then may as well buy it. Never rented a tool before.
Old 09-19-2010, 11:03 PM   #2
nap
You talking to me?
nap's Avatar
here is a site that has a 4 1/4" bit for $67 (sales price, not rental). The 4" is out of stock but costs $56.
http://www.mcgillswarehouse.com/Prod...5412&TYPE=GOOG
Do you need the hole to be pretty? If not, multiple holes by a small drill bit and a hammer will get you a hole, just not as pretty as the core bit.
this place charges $40/day for rental
http://www.a-zrental.com/equipment.a...ry&category=43
this place charges $15/day
I would guess it is going to depend on what you have available close to you when dealing with rental. If buying, you have the world to choose from.
what are you using to power the thing? Any I have used have a large internally threaded boss that screws onto a threaded shaft on the drill.
The Following User Says Thank You to nap For This Useful Post:
BigJim (09-19-2010)
Old 09-19-2010, 11:22 PM   #3
Xtreme DIY'r
I used a friends compressor, air gun & chisel bit
I drilled the outline from both sides w/masonary bit 1st
The Following User Says Thank You to Scuba_Dave For This Useful Post:
oh'mike (09-20-2010)
Old 09-20-2010, 04:30 AM   #4
Tool Geek
PaliBob's Avatar
Red, If you have a hammer drill but not an SDS rotary hammer then I would definitely go with the chipping technique. I have a Bosch SDS Rotary Hammer but every time I needed to drill a large hole I used a local coring service. They would come out for a single hole.
http://www.intracut.com/
The concrete cutting business like all construction is really slow now so you may get a small operator to come out for around a $100, that is if appearance is that important.
I would first drill a small hole from the block side into where the center of a block cell is, to verify that it is not filled with concrete which also may include #4 or bigger rebar.
Let us know what happens.
& Stay Safe
.....Bob Lavery
The Following 2 Users Say Thank You to PaliBob For This Useful Post:
oh'mike (09-20-2010), steveel (09-20-2010)
Old 09-20-2010, 07:14 AM   #5
Super Moderator
Last 4" diamond coring bit I bought was over $400--The prices at that site are cheap---I just wonder about the quality--
oh'mike is online now   Reply With Quote
Old 09-20-2010, 01:08 PM   #6
Wire Chewer
Hmm I could maybe do that. I suppose I could buy myself a masonry bit set, could be good for various projects. I do have a hammer drill.
The blocks arn't filled unless that particular spot is for some reason but I doubt it. There are various areas where there are nail holes and I can put a coat hanger right through. I want the hole to look decently nice but does not have to be perfect. Just don't want it all crooked and bigger then 4 inches. The vent should be able to cover the hole without it looking bad.
Old 09-20-2010, 01:58 PM   #7
DIY Hack
Mr Chips's Avatar
I would first drill a small hole from the block side into where the center of a block cell is, to verify that it is not filled with concrete which also may include #4 or bigger rebar..
Yea, if you rent and hit rebar, you'll damage and potentially ruin the bit, which will result in additional charges and loss of your deposit. some places charge for wear, in addition to standard rental fees.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-20-2010, 02:29 PM   #8
nap
You talking to me?
nap's Avatar
use a wet core bit. They are designed to cut rebar as well as the block/brick.
btw: you can destroy a dry core bit by running it too fast as well. No return of deposit with that either I would suspect.
Old 09-20-2010, 02:32 PM   #9
DIY Hack
Mr Chips's Avatar
if it's hollow block just hammer and chisel it, use a smaller bladed chisel or even a bull point.
make a hole in the center with the biggest bit you own, then mark the edges, score and chisel it out.
The Following User Says Thank You to Mr Chips For This Useful Post:
Old 09-20-2010, 03:05 PM   #10
Tool Geek
PaliBob's Avatar
Red, For your hammer drill I would get a set of long SDS bits. They will work in a conventional drill chuck, just not as fast. The first hole through the block & brick should be as straight and level as possible.
I would start from the block side of the wall and try to get the first 1/2" center hole to align with the middle of a web opening in the block. Mark the perimeter with a magic marker using the 4" tubing as a template. If this is for a 4" Dryer vent that will exit on the brick side of the wall then you can use the vent hood to mark with heavy duty tape the maximum outside opening.
You can buy a single block or two to practice on so that you don't scar your bricks beyond the vent hood.
You can get a set of five 16" long SDS bits for $20 from HF or get by with a single 1/2" masonry bit that is at least 12" long. By making a series of holes around the inside of the 4" perimeter and chipping out the remainder with a long 1" cold chisel you should be good to go.
http://www.harborfreight.com/5-piece...set-46755.html
http://www.harborfreight.com/12-piec...set-66440.html
And finally a 3 lb hammer, if you don't have one, works much better than any carpenters hammer.
http://www.harborfreight.com/3-lb-sl...mmer-6748.html
& Stay Safe
.....Bob Lavery
Old 09-20-2010, 07:05 PM   #11
Wire Chewer
About 55/day to rent, so I might look at just doing as suggested and just drill lot of small holes, and chizel away. They close at 5 so I can't bring it back the day I pick it out, so in reality it would cost me 110 bucks. If I end up stuck late at work, then add another 55 bucks... so it could be expensive.
I'm even wondering if I should just hire this out. What kind of tradesperson would do this, a masonry worker perhaps?
Old 09-20-2010, 07:14 PM   #12
nap
You talking to me?
nap's Avatar
If you fly me up there and buy dinner, I'll do it for free.
It really isn't that difficult. The multiple small holes (as close as you can get) allows you to simply whack the center with a hammer to break free the remaining connections. Just don't hit so hard as to move the entire brick or block rather than breaking the connections.
Old 09-20-2010, 08:32 PM   #13
DIY Hack
Mr Chips's Avatar
Heck, I'll pay my own airfare if you pick-up the bar tab...
it's an easy job, don't sweat it
Old 09-20-2010, 09:53 PM   #14
Wire Chewer
Oh I'm sure it's easy, but just debating if it's worth buying the tools required to do it. Guess I may need to do this again in the future, so may as well bite the bullet now.
Old 09-21-2010, 01:32 AM   #15
Tool Geek
PaliBob's Avatar
Red, Here is a Canadian source for masonry bits that will fit your Hammer Drill. You don't have to buy or rent a rotary hammer. You can get by with one or two (nice to have an extra) of the 3/8' x 12 Masonry drill bits.
http://leak-proof.com/catalog/grouti...352_30_34.html
You will also need a long shank cold chisel but since these are not too common you could use a small 1/4" x 12" star drill or even a long punch to break out the concrete webbing after you've drilled around it.
http://hand-tools.hardwarestore.com/...ar-drills.aspx
By getting a concrete block to practice on you will also be better equipped to judge where is the center of an open cell on your wall.
& Stay Safe
.....Bob Lavery
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 07:59 AM
2 100 Amp Services to Rental Units (380 foot run) hwbnd09 Electrical 2 11-03-2009 08:43 PM
labor costs per sq. ft. awk08 Building & Construction 1 04-06-2008 10:12 PM
Building Labor Costs SunNdeLight Building & Construction 2 09-17-2005 10:33 AM
