Troy-Bilt 2-Cycle Gas Trimmer Will Not Start - Tools - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 06:55 PM   #1
I have a Troy-Bilt 2-Cycle Gasoline Trimmer (Model# TB70SS) that I purchased about 1 1/2 to 2-years ago and it will not start. Enclosed are photos of the unit.
I've done the following and it still will not start:
  • Checked the On/Off Switch
  • I've replaced the gas and added a fresh new tank of 40:1 mixture of 2-cycle oil and unleaded gas
  • I've checked the Spark Plug arrestor and cleaned the screen with a wire brush
  • I've replaced the spark plug with a Champion DJ7Y spark plug with a .025 gap
  • I've inspected the air filter and it looks to be in pretty good condition.
  • I've pulled the starter rope numerous times just in case it is flooded
One of the things I've noticed is that the Primer Bulb will not work correctly. When I press it in to start the fuel flow, it will not depress or return to its normal state immediately, it takes several minutes. Therefore, I can't press it 10 times as the manual states to start it. Does this mean I need to replace the primer bulb? What could be the problem HELP!!!
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start-weed-eater_troybilt-001.jpg   Troy-Bilt 2-Cycle Gas Trimmer Will Not Start-weed-eater_troybilt-002.jpg
g8tkeeper is offline   Reply With Quote
Old 08-25-2009, 08:44 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Have you checked to make sure you have spark? Will it fire if you give it a shot of ether? Does it seem to have good compression?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 08-26-2009, 08:26 AM   #3
47_47's Avatar
Rewards Points: 74
Try loosening the fuel fill cap and press the primer.
47_47 is offline   Reply With Quote
Clothes Washer Will not start cycle allenzachary Appliances 6 01-11-2011 08:57 PM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
Heil Furnace will not start up after cycle pcoslow HVAC 6 04-19-2009 10:01 AM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 08:53 PM
