Troy-bilt 020337 Not Starting - Tools - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 05:45 AM   #1
Rewards Points: 77
I have a 2010 Troy-Bilt 020337 2550 psi pressure washer that will not start. The last time it was used, was about two months ago. I did have a difficult time then starting it. I had to pull the engine apart because it had seized for sitting so long (8-10 months), but none the less it did work with no problem. Maybe in not understand the "fresh start" system, but it will not start. I've never had any problems with water pressure or lack of water pressure with the machine, so I dot think its the water pump...
Justins1171 is offline   Reply With Quote
Old 03-03-2012, 07:13 PM   #2
Missouri Bound's Avatar
Compression, fuel and spark. That's all you need to worry about.
Do you want it your way or the right way?
Troy Bilt mower problem noquacks General DIY Discussions 11 08-03-2011 06:48 AM
troy bilt n779 pony scorpiorose52 Landscaping & Lawn Care 0 06-22-2011 03:46 PM
Troy Bilt Gas Cultivator dangier Landscaping & Lawn Care 0 05-02-2010 09:48 AM
Ridgid or troy bilt Pipeline Tools 1 11-23-2008 11:41 AM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 08:53 PM
