Trim Head Screws Lament! - Tools - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 05:59 PM   #1
trim head screws lament!
my lumberyard used to carry a coated exterior trim head screws. a 5 pound box was about $10. they were square drive and awesome. i used them for exterior and interior trim.
now for some reason they no longer carry them and only have stainless.
so does everyone else.
i seem to be the only person who hates using the stainless trim screws. for one because you get about 20 screws for $20.
but worse, they are so soft and strip half the time. one little hiccup with the driver or bit, the screw is trashed. want to remove the board for any reason? forget about it!
this is unacceptable.
where can i still find these coated trim head screws? they were not stainless, but had a green coating similar to the treated deck screws.
(another store sells interior trim screws, not stainless, and i have the same issues with those. i never had any problems with the coated square drive.)
thanks.
wombosi is offline   Reply With Quote
Old 02-15-2011, 12:06 AM   #2
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
You can try McFeelys. If they don't have them, nobody will.
WirelessG is offline   Reply With Quote
Old 02-22-2011, 02:50 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Most of the McFEELY'S Trim Heads are stainless but here are some standard Grey Heat-treated
click here: steel trim screws.
McFEELY'S is running a $1 Shipping & Handling on any order.(expires 2-28-2011)
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-22-2011, 08:44 PM   #4
Household Handyman
Rewards Points: 1,408
Fastenal carries a good trim screw compatible with different pressure treated woods and composite decking materials. The drive is the "six-lobe" type though, not square. They are not $2/lb. either, a bit expensive but are self-starting with those funny cut first few threads. I've found these to work real well with PT lumber, drive well, and don't seem to break as often as SS. SS is a actually a soft steel by nature and stretches quite easily.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
