Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 10-14-2009, 06:31 AM   #1
sweaty
Treadmill Noise
I just got a used treadmill and it makes excessive noise. Any ideas?
sweaty is offline   Reply With Quote
Old 10-14-2009, 08:15 AM   #2
the Musigician
DangerMouse's Avatar
Treadmill Noise
kinda need a bit more info.....
manual? electric? motor noise? "the roller bearings are shot" noise?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 10-15-2009, 06:33 AM   #3
sweaty
Treadmill Noise
It is a Pro Form 400 GI, electric. The sound comes from either the belt or the roller.
Old 10-15-2009, 06:40 AM   #4
the Musigician
Treadmill Noise
i'd check the bearing brackets and mounts to be sure they're screwed down tight. they can come loose over time.
is it noisier when you use it?
DM
Old 10-15-2009, 03:28 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
Treadmill Noise
If you don't think it is fixable do not throw it away. You can use it for an automatic feed for a do it yourself belt-sander. A guy made one over on the woodworker forum that is linked to here. He did not have the feed in yet but the rest of it looked pretty cool.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 10-21-2009, 01:02 PM   #6
Treadmill Noise
shouldn't there be some kind of return policy or something? I am sure the manufacturer will take the product back if there is something wrong with it
drillbitter is offline   Reply With Quote
Old 10-21-2009, 01:20 PM   #7
the Musigician
Treadmill Noise
probably not, he said it's used...
DM
Old 10-21-2009, 09:54 PM   #8
Treadmill Noise
We have an elliptical machine, which is different obviously, but one of the things you can look out for is joints that creak and WD40 should help. You DO NOT want to put WD40 on any motors or bearings, but most exercise machine is going to have non-mechanical joints that could make noise.
I guess the trick, is that you first need to figure out where the noise is coming from.
richardballast is offline   Reply With Quote
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 7 05-07-2010 11:24 AM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 12:25 PM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 09:38 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
