Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-06-2007, 06:18 PM   #1
Toro Snowblower problem
I have a Toro Snowblower model #38405 which has a 2 cycle 3.5 Hp motor. It starts fines, however will backfire about every 10 seconds while running. I cleaned the carb jet, put in new fuel, and checked the spark plug. Any idea what is causing my backfire?
mbgrdido is offline   Reply With Quote
Old 12-06-2007, 09:30 PM   #2
You should probably use 93, high octane. It's backfiring because the fuel in the combustion chamber is not burning completely.
handy man88 is offline   Reply With Quote
Old 12-07-2007, 08:48 AM   #3
RippySkippy's Avatar
Does that model have an air filter? If it does you might clean or replace it.
RippySkippy is offline   Reply With Quote
Old 12-07-2007, 11:28 AM   #4
Thanks I will give this a try.
diagnose house wiring problem brhodewalt Electrical 7 05-06-2009 10:03 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
